BX weight lifting test
   / BX weight lifting test
Good information.
What loader do you have on your BX2360?
How much rear counterbalance did you have when you performed the FEL tests? (tires/wheel weights/3-Pt.)
Did you have any weight in the bucket when you performed the 3-Pt. lift tests?
It has the 243 loader. The rear had 110lbs of wheel weights, quick hitch. and carryall when testing the loader. The loader was empty when the rear was tested.
And I don't drive it that way. When actually moving the blocks I had 6 in the bucket and 9 on the pallet.
Bruce
   / BX weight lifting test #12
The FEL test had the front tires squatting pretty good. I haven't ever tested the pressure on my loader, but seeing what it does to the R1s when I have a load that is near max before I go into relief I don't think I could get much more lifting capacity.
I have wanted to do a test like this about the only thing I have enough of are bundles of shingles. I might need to weigh a couple on a bathroom scale and get an average weight and go for the limit.
   / BX weight lifting test #13
Great feedback. Thanks for taking the time.
   / BX weight lifting test #14
Great demo--thanks!
   / BX weight lifting test #15
A Max28 can handle about 800 - 1,000 lbs on the bucket forks depending on how far load is from pivot pins and a ton on the 3 pt. carry all.
BX does ok for it's size.
   / BX weight lifting test #20
Just in case anyone is wondering... yes a BX will lift a 62" flail mower and it works it just fine. Weighs about 700#.
I use it for mowing my lawn when I feel like switching it up from a rotary.
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
New Wolverine 72in Skid Steer Brush Cutter (A59000)
New Wolverine 72in...
2014 Ford Fusion SE Sedan (A56859)
2014 Ford Fusion...
2020 DRAGON ESP...
2022 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A55973)
2022...
