Any Ideas for a Cheap Compact Rear 3 Pt Counterweight?
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #62
I'm keeping an eye out for an interesting old wood stove to fill with concrete.
Wood Stoves, Fireplaces, Pellet Stoves, and Masonry Heaters
Removing an uncertified wood stove is not required when you are buying or selling a house. We encourage using cleaner home heating options and recycling uncertified stoves.
Selling an uncertified wood stove is illegal. Selling a house with an uncertified wood stove is legal.
Bruce
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #63
Lots of great ideas. Thanks everyone for your input.
Question: Does anyone have experience with this Titan Ballast Box?
Amazon.com: Ballast Box 3 Point Category 1 Tractor Attachment: Home Improvement
At $255 with free shipping through Amazon, it's hard to justify spending time building one. It seems to be well reviewed but appears to be made of rather thin metal. I suppose it could be filled with concrete if it started to fall apart.
My neighbor just bought one. Ordered on Tuesday at 11am and it was at his door on Wednesday by 5pm with standard shipping. We live in PA though.
The box is very nice and has a number of nice features. Receiver built in. Door to empty. Tubes for shovel/rake/etc. pallet forks fit underneath. Quality and thickness of steel is on par with OEM's.
Suggest ordering direct especially after signing up for their news letter and receiving 5% coupon. Plus it was slightly less on their website.
Bottom line: highly recommend.
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #64
Titan seems good value for the dollar, I just bought their 5/16" thick skid steer blank plate. Nice heavy stamping, grit blasted to bare metal for welding and paint, and top edge welds are very well done.
Comparing that to my other 1/4" thick plate, the 5/16 pates seems way thicker , even if is only another 1/16" thick.
$255 is a bargain
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #65
Might be free if you are lucky: http://www.tractorbynet.com/forums/attachments/376890-contest-giveaway-titan-attachments-one.html
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #66
It does look nice,.... new.... but ...
I hate rust,... and who is going to store a ballast box inside?
It may be a bit of a nuisance to build one, but I vote for a plywood form with molded edges/corners, and filled with as much concrete as desired.
It will NEVER get rusty!
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #67
A co-worker cut a plastic 55gallon drum in half, drilled a hole in each side, ran a drawbar (with 3 pt top part too) through the holes. Then a couple pcs of 1.5" pvc pipe Standinding up in the drum. Filled it with concrete. He uses the pipe tubes to put he yard tool handles ( shovels, hoes, rakes....) in for transporting around his farm. He says he put a hitch receiver in the back too. so he can pull a small trailer. I thought that was a cool idea.
It depends on how much weight you feel you need.
A 55 gallon drum filled with Sackrete @128 lb. per cu. ft. would be 940 lbs. total.
For some that might be enough, but many need 1200 -1400 lbs. or more, and a 55 gal. drum could only do that with a mixture of lead and concrete.
   / Any Ideas for a Cheap Compact Rear 3 Pt Counterweight? #69
Mine does, About 300 lbs of Concrete, +400 lbs of steel. In need to paint the outside of the concrete to seal it.
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
2000 Safari C-Series 425 40ft Panther Motorhome (A49461)
2000 Safari...
2020 CATERPILLAR Tl1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K...
CAT 430E BACKHOE LOADER (A50854)
CAT 430E BACKHOE...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
