Replacing trailer brake battery with capacitors
   / Replacing trailer brake battery with capacitors #1
CajunRider
Cajun Land
Kioti DK45
My trailer was bought mostly to tow my tractor around so it doesn't get much use. It seems that every time I use it I have to fix a dead trailer brake battery. Has anyone of us here ever replace the trailer brake battery with capacitors? I think capacitors will be superior to batteries in this application.
The load requirement is low so the cost is reasonable. The capacitors will charge up much quicker and require a whole lot less maintenance than the batteries.
   / Replacing trailer brake battery with capacitors #2
I like the idea, but it probably won't get you out of a ticket, if it ever was checked, don't know. You could put the capacitors in a battery case and it would look like and do just what a battery does.
Seems like as long as the capacitors can power the brakes long enough to get the trailer completely stopped in an emergency, they would be fine. And zero maintenance.
   / Replacing trailer brake battery with capacitors #3
The law requires the brakes hold for 15 minutes on trailers requiring brakes. That's usually at 3000#
So no, capacitors would not be practical.
Now to your battery. I have owned 7 or 8 trailers over the last 25 years and have maybe replaced the batteries every 5 years. Get them on EBay for about $12 to my door. If you are having this much issue you have other problems or use your trailer so little it's not necessary for you to own one.
A cheap $20 battery tender or solar panel should take care of your issues.
   / Replacing trailer brake battery with capacitors #4
I just replaced a 10 year old breakaway battery last week. I'm good with that interval. There are few trailers that see LESS use than mine.
   / Replacing trailer brake battery with capacitors #5
What he said... :thumbsup:
Solar charger about $25 at Walmart.
https://www.walmart.com/ip/12V-Sola...1763&wl11=online&wl12=700878309&wl13=&veh=sem
Trailer brake batteries on Amazon for $14.
   / Replacing trailer brake battery with capacitors #6
Get some battery clamps , make a cord that goes from your break away battery to reach your tractor battery . When you tow it , just hook to the tractor battery and you are good .
   / Replacing trailer brake battery with capacitors #7
   / Replacing trailer brake battery with capacitors #8
My trailers are stored in a barn, solar doesn't work there. Jon
Put the solar panel in a window or mount it on the outside wall and run the wire through the wall with a grommet and some silicone sealant.
If you have power in the barn, get a small AC charger/maintainer. They are dirt cheap as well.
   / Replacing trailer brake battery with capacitors #9
Ditto the seldom used trailer. I have a jump pack that I built a carrier for on the tongue. When I need the trailer I drop it in and plug it into the breakaway circuit. It's a large one that has a lead acid battery, not the lithium ion jokes.
Dual purpose device.
2016 CATERPILLAR 259D SKID STEER (A50458)
2016 CATERPILLAR...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52128)
2017 Yale GLC050VX...
CATERPILLAR 305CR EXCAVATOR (A51242)
CATERPILLAR 305CR...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2017 DODGE RAM 5500 HEAVY DUTY SERVICE TRUCK (A51243)
2017 DODGE RAM...
