JD 770 electrical starting issue
/ JD 770 electrical starting issue #1
newtron
Port Townsend, WA
so I've looked thru the forum trying to solve this problem but I'm at a loss.
So I was driving the tractor, shut it down, and then it would not start again. I turn the key and there is nothing, no power, lights, anything.
I have tested voltage at battery and at the starter and get 12.4. I can get 12 volts all the way to the ignition switch. Then I turn the key and get nothing. I've pulled the panel apart and have got the ignition switch out. There are 5 wires to the ignition switch, . 1 wire is is 12v supplying power to the ignition switch and it has its own clip, then there are 4 wires that come off the back into a separate clip. The strangest thing is if I disconnect the the 4 wires from their clip (leaving the 12v supply connected) and I turn the key I get 12volts across, and If I turn it to "crank" I also get 12v across.
As soon as I reconnect the 4 wires back into the tractor and I turn the to "on" there is no voltage anywhere. There is non at the 12v source to ignition or any of the other wires. Where do I go from here? also how is an ignition switch grounded? and could insufficient ground cause all this even though I'm getting proper voltage?
Thanks
/ JD 770 electrical starting issue #2
I have a PDF of the Tech manual you're welcome to, all the wiring is in it.
Shoot me your email if wanted
Joe
/ JD 770 electrical starting issue #3
Thanks
Could it be something as simple as a safety switch, (pto on ,clutch safety switch ) ?
/ JD 770 electrical starting issue #4
How old is the battery? Just may have 12v from a drained battery, but not enough umph to start. If battery checks out, then on to the next test.
2014 Infiniti QX60 SUV (A66738)
2014 Infiniti QX60...
1987 Fruehauf MC 307 Insulated 7,500 Gallon T/A Chemical Tanker Trailer (A68183)
1987 Fruehauf MC...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
2016 Ford Expedition SUV (A66738)
2016 Ford...
ENCLOSED OPERATOR CAB (A68842)
ENCLOSED OPERATOR...
2024 KUBOTA SVL97-2 SKID STEER (A65056)
2024 KUBOTA...
