Gravel Drive way Issues
/ Gravel Drive way Issues #1
summit151
Drayton Valley Alberta
Massey 1135
Hello. I was wondering what everyone does to reclaim the gravel that goes into the grass ditches after a winter of snow plowing? I was thinking of building a gravel drag bar at a angle so it would push the rock up and onto the road. Looking for a idea that could be used behind a atv or a skid steer
/ Gravel Drive way Issues #3
Everyone has this problem to different degrees.
Not sure how you would control side drift of a bar dragging at an angle? Especially if using the ATV.
To use the skidsteer would involve an elaborate setup that fastens to the bucket? Or replaces the bucket?
Hopefully someone will chime in with a homemade solution!!!!
Best time to do this is before the ground thaws. Greatly reduces bringing foreign material up onto the roadbed.
/ Gravel Drive way Issues #4
I have way too much of this now. We never had frost in the ground and at times the blower took a good scoop of my limestone screenings. In one place, I used the light weight Steiner and bucket doing the hard work with a leaf rake. Not much fun.
I just discarded the material. Too much soil in it for my liking to put back on the driveway.
The rest of it will go on HER Saturday morning honey do list.
EDIT: I have a tow behind self powered sweeper (Smyth Welding) for the Steiner, but I don't won't to wear out the broom on aggregate and sandblast the hopper, so I don't use it for this. Plus it would gather up a lot of dead grass and soil, which I would simply discard..
/ Gravel Drive way Issues #5
I use a front blade to reclaim the bulk gravel from 900' driveway. What's left I use a hand rack and/or hoe...it's an annual PITA. For you perhaps an offset back blade that will tilt horizontally might work?
6 Way Deluxe Scrape Blade for Compact Tractors
/ Gravel Drive way Issues #6
Could you hire someone with a rotary sweeper on the front of their garden tractor?
/ Gravel Drive way Issues #7
I set my landscape rake at an angle and drag it along the side of the driveway. This will recover most of the rocks and kick them back into the driveway. It usually takes a couple of passes. Unfortunately my driveway is in bad shape right now, I think I need to get a land plane.
Ok thanks for the ideas guys. I wonder if a rotary sweeper on my skidsteer would work? But I wouldn't be able to drive along the drive way and sweep it would rut the side of my drive way bad. I would have to sweep from the centre then sweep and drive backwards and make passes
/ Gravel Drive way Issues #9
A skid steer would do way more damage than what it fixes. Best to leave it parked.
/ Gravel Drive way Issues #10
PS344.png PS344 | PowerBroom™ | Shindaiwa-USA.com
bought the above awhile ago, not cheap, heavy but it beats racking! fling it into the bucket then dump it.
/ Gravel Drive way Issues #11
Having done that for all of my life (dreaded every spring when my father would tell me and brother to clean up the driveway and the ditches), I use a stone rake, back drag with the lip of my loader bucket, and/or a Stihl power paddle, depending on the amount of material. Sure beats the rake and wheelbarrow of my youth!
Will
/ Gravel Drive way Issues #12
I have a backpack blower that puts out a good volume of air at a high velocity and use that to blow the displaced stone back onto the driveway. My drive has ス" stone that the blower moves readily.
/ Gravel Drive way Issues #13
I have a big Stihl backpack blower and do the same. Works pretty darn good, just walk along and blow if back on my lane.
/ Gravel Drive way Issues #14
Same thing here with the landscape rake followed up by a landplane. I maintain a mile driveway and a landplane is an incredible piece of equipment for gravel drives.
/ Gravel Drive way Issues #15
I do the same as dinmis: landscape rake turned at an angle. Once the gravel is brought back up, I use a landplane to smooth it out.
As stated, expect it to take multiple passes.
/ Gravel Drive way Issues #16
Ditto on the landscape rake set on an angle...having hydraulic tilt is a great advantage...
/ Gravel Drive way Issues #17
My dad has designed his drive way to accomodate snow piles so when spring comes the gravel is sitting on other parts of the actual already graveled portion of drive. The design is basically a huge oval that he is cable of making 360 degree turns with room to spare with a semi truck and trailer.
Now I realize that for 99% of people that's somewhere between impractical and impossible, butbi wanted to throw the thought out there.
He has a front end loader that he uses to scoop deep snow then push the last couple inches into a pile on the fringes of the driveway or rarely used paths to out buildings that are not traveled in the winter. Then come spring melt just spread it back around with the rear blade.
Also worth noting here in southern nebraska we hardly get snow anymore. I can remeber 20 years ago as a kid getting several feet per winter now were lucky to get several inches. (Global warming much) Heck we got 3 inches of rain on Christmas day this past year.
Sounds like a land scape rack or power broom is the best method . My gravel is 1 1/4" wonder if a land scape rack will pick it up?
/ Gravel Drive way Issues #19
We have an 850' drive way - curvy and at a slow incline. Over the years the gravel (3/4 minus) has packed in to give us a very hard base. The drive way has a nice crown with very small drainage ditches on each side. Every year I use a rear blade, set at an appropriate angle and with top and tilt I redo the small ditch and at the same time throw up the migrated gravel - and some dirt will come along with that. After doing this in each direction I will have a nice cleaned up drainage ditch on each side and will have piled up gravel and some dirt on the crown. Then I set the rear blade straight and make a few passes to spread out what I have tossed to the middle. The dirt will end up working its way into the gravel and then not be that visible, and any weeds or whatever will die. This is in Central California - weather and rain patterns elsewhere may make this less effective, but it works well for us. Rarely have I had to do this more than once a year. You can experiment with the blade's angle to see what works best. I usually work it with a couple of different angles.
/ Gravel Drive way Issues #20
Yup!
You have got it exactly right!
A gravel driveway surface NEEDS to have a significant crown to SHED water.
Pulling your gravel back from the edge, and making a meaningful crown, with a straight blade, is the way it SHOULD be done.
The land plane disciples can create a nice level surface, but they cannot pull the gravel in/up from the ditches, to create, and maintain, a MEANINGFUL crown, that will SHED water.
Ever seen a land plane used on gravel county roads, or on a highway construction project?
Skid Steer Tree Spade (A65640)
Skid Steer Tree...
2012 John Deere 135D Excavator (A65579)
2012 John Deere...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A65053)
2018 GENIE GTH-636...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A65643)
1994 SHOP MADE...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
