Reclaiming overgrown land
/ Reclaiming overgrown land #2
CASE 55C SPECS: TractorData.com CaseIH Farmall 55C tractor information
You did not mention how much forest land you want to clean up, but judging by the roads a considerable amount.
You seem happy with your heavy Case tractor, chainsaw and Bush Hog.
I also suggest a battery powered reciprocating saw for limbs and saplings under 2". Much safer than a chainsaw for small stuff. Reciprocating saw blades are much cheaper and easier to change relative to saw chains. I have found Milwaukee's THE AXE blades superior to pruning blades.
I leave tree stumps, after treating with full strength herbicide to make sure they are dead. Locusts are about the toughest of small trees to kill.
For removing softwood roots, vine roots and corms from below ground level I have had success using a spring protected Dirt Dog (brand) Field Cultivator in my Florida sandy-loam. I had it on my Three Point Hitch yesterday, pulling out subsurface Palmetto calves and wild grape vine roots up to 2-1/4" in diameter.
LINK: http://www.tractorbynet.com/forums/attachments/339095-dirt-dog-all-purpose-plow.html?highlight=
LINK: DD FIELD CULTIVATORS
For overgrown pasture, previously packed by hoofed animals, you may need a moldboard plow to cut through the packed soil and roots. The Dirt Dog Field Cultivator is a secondary tillage implement which has worked 100% for me in woodlands soil but has not been up to primary tillage in hard packed pasture. In really difficult soil you may want a Disc Plow, which is NOT a Disc Harrow, rather than a moldboard plow, however they have a slight tendency to roll over some roots you might wish to sever.
A Chisel Plow would be another alternative. However, a turning plow will probably do more to improve the tilth and fertility of your pasture expansion.
Moldboard plows, Disc Plows and Chisel Plows are all primary tillage implements.
I have hiked a fair amount in Missouri. I saw considerable clay in parts. More loam in the south. How is your soil, generally?
What have to done to your tires to keep air in them? Usually Locust thorns work into tires, resulting in flats.
/ Reclaiming overgrown land #4
That frizzed out stump is exactly what you need to see when the object is to kill stumps.
I mow several acres of lots, two to three times per year, so my Rotary Cutter is kept sharp and the 1" and 1-1/2" brush is severed clean. Some attempts to grow back. Thankfully, I have no Locusts.
You never want to mix subsoil and top soil. As long as your clay is consistently 24" below grade you can still use any of my subsoil trash removal suggestions in Post #2. The Field Cultivator would probably disrupt soil levels least. The tines are only 1/2" thick.
Nothing yet. Just keep pullling them out hoping they don't make it through. I could slime the fronts but rears are loaded with washer fluid. Just hoping if I get one its on the front. Won't be cheap draining and refilling rears.
/ Reclaiming overgrown land #6
Whatever you do, this time of year is good time to do trimming with saw and lopers, you can get in close and see stuff.
Personally I don't like pasture land, cause I am not farming, so it is an ugly landscape to me. I would start by making trails. So you can get through areas. Then look at thinning.
I debate between cutting stumps low, and pulling and pushing them. Pulling stumps makes a big hole.
Right now its so thick with crap trees that its useless land. It's so thick you can't even walk it so I don't really mind clearing it out. Another couple of years and I'll need a dozer to clear it. As far as the rest of the timber it has a lot of good oak and some maple. I'm not wanting to clear it, only thin the underbrush and selectively cut some of the trees to allow some light in.
/ Reclaiming overgrown land #8
Fun post. I think that thinning out the woods is one of the most fun things to do on a tractor!!!! Love the before and after look of it, and how much nicer everything looks. Around here, trees are weeds, and if you don't keep up with mowing, they come back thicker then before.
/ Reclaiming overgrown land #9
You seem to have done right well on those areas already cleared.
Maybe think about a root rake for the loader. One that can get under and lift the roots. That will let you work forward on areas removing both tree and root ball with the dirt shook off. With the forks under the roots and lifting and curling you will get a lot of front wheel traction. The curl usually does pretty good at lifting and loosening the roots.
Eddy I agree with you. While its been hard work and I'm currently covered in cuts and scrapes from thorns from the waste down there is something oddly therapeutic about clearing up the land. Our family has enjoyed it so far as well. We've been taking evening walks through the new areas I've cleared and the kids have enjoyed it.
Egon thanks for the suggestions on the root rake. I may have to look into it. I've never used one before. I'll have to figure out a way to keep those pesky ads from popping up on the computer when I start looking. They are starting to tip my hand to my wife anytime I start looking at something new to buy.
Here's a quick video of the brush hog in action
20170322_094306_1
Also have some thunderstorms moving in today. Yesterday I went out and dammed up across the ravine about 5 feet high. While I don't expect it to hold water I'm hoping to go take a look when some heavy rain hits and see how fast the runoff starts to fill the area. I'm expecting it to be enough to just blow it out if we get heavy rains. It looks like I have about 16 acres total that drains through this area.
2017-03-24_08-34-56
/ Reclaiming overgrown land #11
Nice project and pics! (by the way, I'd like to see some of them larger and play that video, but they all link to a yahoo page requiring a login I do not have)
I love the topography of your land. 16 acres through that ravine and it was dry enough to work the soil that easily? Is there normally a small creek in there?
My own 19 acres of land was also regrown, young forest full of nasty saplings and invasive bushes. I started by brush hogging mostly, but had enough 3"+ trees and large bushes that I found it easier to carefully bulldoze with my front loader and just get a lot of the stuff dug out, stumps and all. But if your brush hog is chopping through easily and leaving nice, blown out little stump fragments, I wouldn't even work the soil at all. Just keep mowing for a couple years and the grasses will take over. The little stumps will just start to disappear, and you can leave all that nice top soil in place.
Deezler thanks for pointing that out. I have changed permission settings to public on the photos now. You should be able to open them larger including the video.
The ravine has a small amount of water about 50 yards east. We have had no snow this winter and rain for some time. Everything is really dry so I'm glad to see some storms today. Usually the bottom of that area is always somewhat wet. I agree with you on the stumps. Anything that will hurt a finish mower I've cut down to soil level. The rest I will leave as suggested.
/ Reclaiming overgrown land #14
For the ads most browsers have a "private mode". You have to start it up each time you open the browser but it will cover your tracks enough that the ads don't pop up.
Too late for that. My wife is already on to me and probably has a count on my implements. A couple of years ago I made the mistake of organizing all of them in a nice row instead of leaving them scattered around the property. She immediately asked when I bought two of them I had had for a few years. Lol.
Re-posting my aerial pic from google earth. Not sure how but I managed to delete that post clicking from my phone. Red box is the area I am clearing. Yellow line is the ravine. Three sides of the ravine form a bowl that water flows from.
aerial
/ Reclaiming overgrown land #18
Any osage orange over 4-5" in diameter will make a great fence post. They are ugly and crooked but rot resistant. You may not have a fence planned now, but you might want one in the future. Just cut them up into 7.5 foot lengths and pile them up out in the woods. That pile will still be a good resource 70-80 years from now...
Osage orange also makes some really good firewood. Have to be careful not to burn too much at a time.
/ Reclaiming overgrown land #20
jk96, looking at your pictures, a forestry mulcher would make short work of clearing your land. That's if you wanted to hire the work out and there were contractors with such equipment available for hire in your neck of the woods. A forestry mulching machine would shred and chip that including the roots in no time. No stumpage at all left sticking out of the ground.
I have watched them go through the woods like a Tasmanian Devil :shocked: clearing right-of-ways, ATV trails, food plot areas, etc.
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
Skid steer Backing Plate (A62679)
Skid steer Backing...
Titan Hydraulic Hay Bale Handler (A62613)
Titan Hydraulic...
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
2021 Kawasaki Teryx KRX 1000 SE (A62679)
2021 Kawasaki...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
