Sometimes one just has to be creative with whatever one has on-hand! If you look at my avatar you'll see:
1) Toothbar on bucket (had I had this from the start my life would have been a LOT easier- really hard to move logs and stuff around with just a smooth bucket edge!);
2) Way out back there you'll see my wood hauler/skidder- an old car hood (or truckhood- I think 70s era Ford truck hoods are best), had several hoods I unearthed from the property- no longer use them because I ran out of them (they wear, and I have a totally different firewood scheme now);
3) Box blade - a VERY stout box blade which one can also use as a push blade (in reverse- I've run backwards curling a bunch of brush while pushing another pile behind me), and, as I did for a stint, turned the rippers backwards and set plywood inside the box (curl in back edge of box held the other side of the plywood) which made it into a box for hauling (hauled cut wood), and, of course, it makes for a great ballast piece;
4) Rotary cutter - most used item for me as I've got a lot of brush and grass to deal with (have two tractors and two bush hogs).
Have a winch around, or, in my case, a cable puller (I have one of these:
The More Power Puller®, Portable Winch, Cable Puller, Come Along Winches | By The Wyeth-Scott Company - steel cable because I've got a lot of stuff to snag on). I got one of these after using a regular come-a-long for a long time, having them jam and just outright start feeling less than stable. Viable for smaller equipment rescues. I thought about an electric winch that can mount to a receiver hitch, but that's a fair amount to lug around and then one has to have available battery power (in most cases getting unstuck really only requires a few feet, and this is readily done by a hand winch).
At least one grab hook on the loader bucket: I have three on my
B7800; dealer would only install ONE on my KIoti's bucket- I will look to add more.
Carry an assortment of lynch pins and other clips.
Be sure to outfit work lights if you don't already have them. My wife was telling me that she didn't want me out working at night. After I installed work lights on my
B7800 I was able to react to many emergency situations when it was dark out: wife no longer suggests a night time work ban
