BX70 -vs- B01
/ BX70 -vs- B01 #1
Michael Aos
Gold Member
Colorado Springs
Kubota BX2370-1 RTV500
Went in to the dealer expecting to purchase the BX1870. Wound up with the BX2370.
Now I wish I would have gotten the BX2670 or the B2601. Not quite enough to upgrade at this point though.
I'm also finding the more I use it (I'm at ~37hrs now), the less I'm inclined to impulsively upgrade.
It's too small to go over the side of a 30yd dumpster (I knew that going in), but it fits inside nicely.
/ BX70 -vs- B01 #2
Not quite sure what you're looking for... BX2370 to BX2670 is same machine with a couple more horsepower, for maybe $1400 more.
B2601 is a larger frame tractor, larger wheels, etc, for maybe $4000 more.
Pete
/ BX70 -vs- B01 #4
As the owner of a BX1870, I'm not sure I understand the appeal of the BX2670 over what you've currently got, since I'm not sure when you'd benefit from a few extra horsepower. Even with the least powerful in the lineup, I run out of traction before I run out of oomph, and I feel the HST is working harder than the engine. I suppose there are some PTO implements where more power would be beneficial, but when it comes to mowing and FEL work, I can't see much benefit for the extra cost.
I do sometimes wish for more tractor overall, and moving up to a B series certainly has some appeal. But for my property, the smaller overall size and lower center of gravity definitely have their benefits.
/ BX70 -vs- B01 #6
Unless you are needing the extra Hp at the PTO, I'm not seeing the need for a BX2670. I do understand you desire if you are needing a physically bigger platform. No regrets for me with my BX25D... a little off topic but a few have said the backhoe is an expensive luxury but I don't regret it even if true. That said, I haven't much complained with lack of power (same as your 2370 I believe). I think it is a good size/power match.
/ BX70 -vs- B01 #7
I suspect I could do the same things with the BX2670 at lower RPM's than the BX2370.
Yeah, the B2601 would have been ideal.
And then you'd be looking wistfully at the L2501.
I think I speak for many here, there's no such thing as enough tractor. There's the tractor you have, and the one you wish you could justify owning. I'd love an M7060. I don't know where I'd put it, much less what I'd do with it, but I'd love to own one.
80003CFL (A61568)
80003CFL (A61568)
159120 (A60430)
159120 (A60430)
2014 John Deere 310SK 4x4 Extendahoe Loader Backhoe (A61572)
2014 John Deere...
MacDon 963 Draper Header (A63118)
MacDon 963 Draper...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
2006 Volvo Semi (A64047)
2006 Volvo Semi...
