Buying Advice Need some last minute advice
/ Need some last minute advice #1
chitwood
Snohomish, WA
JD
Hello All. I'm hoping to get some advice to finally push me over the edge and make a decision. I recently purchased 20 acres of land in the PNW, half of which is hilly and partially wooded, with overgrown trails throughout. I would be mowing the other half and brush hogging the trails and overgrown areas. I'll also be using the tractor to help with some landscaping projects (loader work) and grading a gravel road and drive. I've been doing quite a bit of homework and have driven every brand within 50 mile radius (. Mahindra, Kioti, New Holland, Yanmar, John Deere, and Kubota. In the end I have narrowed it down to JD and Kubota, as far as a tractor that fits me. And have finally conceded to HST vs Geared. But I am still unsure as to the model and HP that would make the most sense for my needs.
I am looking at the Kubota L3301 w/loader (21.5K) and L3560 (27.5K)....and John Deere 3032E (21K) and 3033R (28K). Not sure if these prices are in the expected range.
I really felt a difference in quality/capability/weight between the JD E and R series. I wasn't able to test drive the Grand 3560, so I couldn't compare the Kubota.
I appreciate any recommendations of anyone familiar with these models or maybe a higher HP version. This would be my first tractor. Drove them when I was a kid 20 some years ago, but no recent experience.
Thank-you!
/ Need some last minute advice #2
First off, welcome to the forum.
I have a Kioti and am very happy with it. I think you'll be happy with anything you get. As far as size; you'll never regret going bigger.
/ Need some last minute advice #3
G'day Mate and welcome to TBN from Downunder.
You're in the right size for what you've described that you need. It's a big decision... to help you, here's a valuable site for comparison: TractorData.com - information on all makes and models of tractors
Plus there are quite a few TBN members from your part of the world who will, hopefully, chime in with local knowledge.
Enjoy the site.
/ Need some last minute advice #4
I have a Kubota L3560, now with 760 hours, purchased new in February 2013 as Special Order.
This 'Grand L' is my third tractor, each heavier than the one before. I love mine. Four years of living with the comfort and convenience kit that comes in the Grand L package has spoiled me. I will never be able to go back to a bare bones tractor, like my previous two.
I have family in Everett. I have visited Snohomish several times. As the soil can be pretty tough in Snohomish, consider the optional L2296 SSQA {Skid Steer Quick Attach} Round Back, Heavy-Duty bucket. I also added an aftermarket Stebl horn.
As your land is hilly, I recommend having the rear tires filled with fluid, to lower the tractor's center-of-gravity. You will appreciate the four increments of rear wheel spread available on all Grand Ls. Have the dealer set the rear wheels to widest position during delivery assembly. (Tractors are delivered without wheels bolted on.)
My invoice in February 2013 was $27,500, including LA805 FEL, L2296 HD/RB bucket, Draft Control, R4/industrial tires and dealer install of Stebl horn. No sales tax in Florida on ag nor forestry equipment.
Here is a search of the T-B-N archive, using L3560: http://www.tractorbynet.com/forums/search.php?searchid=2772320
I recommend a Ratchet Rake bucket attachment for your trail work and minor grading.
VIDEO: ratchet rake - YouTube
/ Need some last minute advice #6
FWIW, I weighed the E and R issue quite a bit and there is a thread to that effect down in the JD buying forum. I ended up with the 3039R and I'm glad I did. The ability to quickly shed the entire front end loader is a big deal to me. The horsepower seems considerably more than adequate as well. I also went with the H165 loader rather than the H160. There is a little more lift power there and a few other minor things.
Along the way I strongly considered an L3901 Kubota, and a whole bunch of used tractors but the new tractor route seemed a lot better than a low-hour used tractor that has no warranty.
I've only owned it for a week, so I can't say a whole bunch about what it can and can't do, but wood and manure is getting moved like never before so far.
/ Need some last minute advice #8
As others have noted, once you are in the basic ball park regarding horsepower and loader capacity all the brands you looked at make reliable capable machines. Not a lot of practical difference just different pricing and features. I looked at similar tractors a decade ago and went with Kioti based on price and loader capacity. Never regretted it. Figure out your total budget (you will absolutely want a grapple and hydraulic controls including rear remotes for the work you describe as well as a medium duty bush hog or flail mower so budget $4-5K for all that) and then make the best deal you can. Don't shy away from Mahindra or Kioti simply because they have fewer dealers. These CUTs are all very reliable and you won't be back to the dealer much at all. My Kioti is now ten years old and has never been back to the dealer. Still on the original starting battery too!
/ Need some last minute advice #9
I would suggested the Deere 3039R or the Kubota Grand L 3560. You need to check out both of these tractors and decide which one is best for you to operate. Some prefer the two pedal forward and reverse set up and others like the single pedal. Buy the one you are most comfortable with.
I agree with Jeff on widening the wheels and filling the tires for stability. The ratchet rake would seem to be an inexpensive and handy bucket attachment too.
Give some serious thought to open station vs. cab. I prefer a cab hands down but that is me, you may feel otherwise.
/ Need some last minute advice #10
The JD E vs. R is the same as standard L vs. Grand L, Economy vs. Rich!!! The tractor is only one piece of the puzzle, you need implements to be able to put the tractor to work. Even used, implements are not cheap. I bought everything used/2nd hand and still dropped $6k.
The list is long but Hydraulic Top-N-Tilt for building roads is great as well as a grapple. Money is tight for me so I went economy tractor but I have lots of tools to allow it to work for me.
/ Need some last minute advice #11
Teg brings up a good point about the cost of a tractor and the add on features and implements needed to have a complete set up. Most all of us have budget constraints and have to sort out what is important and what can wait. In my plan I prefer to buy the correct tractor that will fill my long term needs first. I add implements that are appropriate as I can afford them, that is an on going adventure. I hope to choose the tractor and each implement so that I don't have to upgrade later on. It can be a costly process with a lot of money involved while most people have lots of other living costs that have to be met with more priority.
/ Need some last minute advice #12
I believe you nailed it! That is one great piece of advice. :thumbsup:
/ Need some last minute advice #13
Careful. It doesn't make much sense to have a powerful luxury cab tractor if you cannot get needed tasks done because you didn't allocate sufficient funds for a mower or grapple etc. A bare bones Kubota L will get just as much real work done as a Grand L of same horsepower. You will soon forget whatever farkles came on the fancy version but you ain't gonna get anything done other than scooping dirt and poop if you don't have decent implements. Many implements can be purchased used but some, like a grapple or hydraulic topping lift and diverter valve are for practical purposes only available new. Given the work you described, I'd keep a mower and grapple with controls as part of the phase one budget.
/ Need some last minute advice #14
The Kubota Grand Ls are about 1,000 pounds heavier than the regular/standard Kubota L series, bare tractor.
I appreciate the numerous farkles which came standard on my Grand L every day that I use it. #1 is the HST/PLUS transmission with Stall Guard.
/ Need some last minute advice #15
Absolutely shocking that Kubota made its name with an obviously outdated and deficient basic HST that still lives in the L series. Hard to imagine getting any work done at all with that old thing. How did anyone get tractor work done without electronic HSTs??
I reiterate that while extra features are nice and eventually become standard on all tractors, one simply shouldn't ignore the more critical implements necessary to get work done. A fancy HST doesn't make up for lacking a grapple or decent mower. If your budget cannot handle fancy tractor plus necessary implements then ditch the Escalade and get the work done with a Suburban.
/ Need some last minute advice #16
I don't see any mention of a luxury cab in jenkensph's reply that I agreed so heartedly with. I give chitwood more credit than that and having common sense to stay within his own personal budget and only purchase what he can afford. ;)
I believe purchasing the right tractor with the future in mind and not wanting or having to trade up in just a few years is more important than having a barn full of implements to start off with.
If some people can afford more and want all the bells and whistles, so be it. It doesn't necessarily make them as a "rich" person. :confused3:
The Kubota Grand Ls are beautiful tractors.
/ Need some last minute advice #17
"My Kioti is now ten years old and has never been back to the dealer".
Yet.....SO MANY here on TBN are consumed by the issue of how close "the dealer" is.
I have bought new cars from hundreds of miles away, that have "never been back to the dealer".
Are tractors different?
I don't think so,...but then,... I have never bought a new tractor.
My OLD tractors have "never been back to the dealer either".
/ Need some last minute advice #18
My Kioti is now ten years old ... Still on the original starting battery too!
That may be worthy of it's own thread, IT. :eek: It might be interesting to know how many people get that kind of lifespan from their batteries.
/ Need some last minute advice #19
Agreed. We are by no means "rich," but were able to get a lot of tractor, bells, and whistles simply by looking at other colors.
... but yeah, the Grand Ls are very nice.
/ Need some last minute advice #20
Yes I do find that remarkable. I even did a thread on it last year sometime. Several people noted that tractor batteries aren't as abused as car batteries and if you keep it on a trickle charger when not in use over the winter that long life isn't that unusual. I've never had a car battery last even five years though.
New/Unused Wolverine Sickle Bar Mower (A65583)
New/Unused...
New/Unused ATS 40 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 40...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2006 Flori Off Road Dump Truck DF40 (A65579)
2006 Flori Off...
2010 Ford F-350 Crew Cab Diesel (A62679)
2010 Ford F-350...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2019 FREIGHTLINER...
