RTVX 900 Starting Expectations
   / RTVX 900 Starting Expectations #1
U00gsw1
Mountain home ar
Ford 1920
I purchased a New RTVX 900 which sometimes chokes out on the first start of the day. After that it starts and runs fine. I understand the use of the glow plug.
The dealer replaced the fuel pump however it still struggles to avoid choking out on the first start of the day.
Is this normal for a small diesel? Thanks!
   / RTVX 900 Starting Expectations #2
:welcome:
Welcome to the forum!
I'm going to move your thread over to our Kubota section to see if we can find you an answer.
   / RTVX 900 Starting Expectations #3
I've never experienced this having owned over 20 Kubotas in the past 13 years but technology changes so it may be part of that. If it starts right every time after the first then it would probably become a non issue or expected way of operation to me and I'd go on and enjoy my machine that has a flukey start the first time for each day.:) No, it would still bother me if no other Kubota ever made did this and the dealers mechanic had no logical acceptable answer.:confused:
PS Sounds like during the night an air bubble is forming in the fuel delivery system or injectors. One could maybe pull the line nearest engine point and let it run fuel for a second then hook back up and see if the problem still exists. Not a mechanic but a logical thinker. :2cents:
   / RTVX 900 Starting Expectations #4
By "choking out", do you mean quite a bit of black smoke? If so, I'd say thats normal. I have the similar engine in my BX tractor and the colder it is, the harder it starts but it has always started for me.
Sounds like good advice. Thank you for your time.
Thanks for the reply. No black smoke. I think it just looses its prime (sometimes). Seems to be doing better lately.
   / RTVX 900 Starting Expectations #7
It is quite possible you have a small air leak. Check all the connections on the fuel line. Both supply line and return.
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58214)
2011 MAGNUM...
296385 (A57192)
296385 (A57192)
2020 CAT 308 (A53317)
2011 Ford Expedition 4x4 SUV (A59231)
2011 Ford...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
