FEL removal - Any tips?
/ FEL removal - Any tips? #1
kspring61
Now Western TN
Kioti DK40SE HST Ford 8N
I am heading down to TN to pick up my DK40SE. I need to bring it back to PA to cut some fields for a guy that lets us hunt his land.
I have a 18' trailer and with the brush hog on the tractor it's slightly too long so I want to remove the FEL and have never done it since I had the tractor.
So, I have read the manual but I am sure guys that have done this have some good tips for making this easy.
Thanks
Kirk
/ FEL removal - Any tips? #2
I would make sure the area where you place the loader is as level as possible. At least from the front tires to the bucket. This will minimize any twist of the loader arms and make it much easier to remove and reinstall the pins.
/ FEL removal - Any tips? #3
If you look at the link below, you'll see many videos on removing the loader from a tractor. Unfortunately, there is none of your exact tractor. Fortunately, most are very similar in process.
/ FEL removal - Any tips? #4
Don't unhook the hydraulics until you have backed out of the hookup about 6 inches. I always forget and unhook them while I'm out putting down the FEL 'legs'. Then I have to cuss myself, get back off, and reattach them to elevate it off the hookup.
/ FEL removal - Any tips? #5
Unhook it on a HARD FLAT SURFACE !!!
Thanks, going to be putting it in the pole building that has a concrete floor.
/ FEL removal - Any tips? #7
I'm assuming you're going to offload both the bucket and loader arms as one piece? I'd get it where you want it to sit, lower the support legs and get them set, and as stated undo the hydraulic lines once you have the loader disconnected from the support structure and the pins are removed from same. Don't move too much beyond getting everything undone so no damage occurs to your FEL hydraulic lines. Once you know you're set and can back out from the FEL, then disconnect your hydraulics, AFTER using the locking mechanism just below the FEL's control stick. This will keep you from bumping it accidentally while you disconnect the QDs under the right side floorboard.
I suggest throwing some significant amount of grease where the pins lock the loader into it's supports. I found mine were pretty dry when I first removed the FEL, and having it removed gives much better access to the connection areas.
/ FEL removal - Any tips? #8
Not sure if I did it when removing the loader, but before disconnecting the backhoe cycle the joystick to relieve the pressure from all the hoses. ( with the engine off )
If you don't you will not be able to reconnect the lines without relieving the pressure. Putting a rag over the female connector and hitting the nipple with a hammer usually will relieve enough pressure to reconnect the lines.
/ FEL removal - Any tips? #9
Heh... this is ALSO a must.
I once had a blade with a hose under pressure. I couldn't get it to connect. I thought, 'Well, I will just push in the ball on the tire and let a little pressure out. I pushed on the lug, had a HUGE spray all over the place. Of course, I was cranking down on it, so my face was about 8" away. My complexion was excellent for the next week. My wife asked me if I was using moisturizer."
Took a week to get the oil completely off my sunglasses.
/ FEL removal - Any tips? #10
Key point BOLDed above.
A rag is a key component of the "wrap and tap" depressurization technique. :D
/ FEL removal - Any tips? #12
Unfortunately... this post came about 6 months too late.
Not this first time that's happened and it's likely happened to all of us at least once.
/ FEL removal - Any tips? #13
Also, if you have an electrically activated 3rd function valve for a grapple or plow on
your FEL, don't forget to disconnect the electrical plug connecting the control
switch on the joy stick to the 3rd function valve.
/ FEL removal - Any tips? #14
That I'm sure would depend on model. I've seen older tractors with the controls mounted to the rear of the loader frame on the main upright, but many modern tractors have the loader valve, 3rd function valve, and the loader control with the switch all mounted to the tractor. No wires run on the removable part of the loader, it's just two extra hoses to disconnect.
/ FEL removal - Any tips? #15
Thanks
Kirk
Perhaps you could just let the cutter hang over the back end of the trailer a bit? In TX we can have around 4' hanging out the back as long as it is flagged properly. I used to flip the rear tail wheel up to save a couple feet, but now I just flay the wheel and strap it to the cutter so it doesn'd flop around.
Maybe it's because I have a grapple and have just gotten lazy, but I am always need to move limbs or tree trunks out of my way when cutting.
With a 20' trailer I can can load all implements and get away with a reasonable overhang. Assuming you have a two foot shorter trailer, but can also get the loader all the way up to the front without the box blade like in this picture, I bet you'll be fine. I leave the tail wheel down now and although it is out there a good ways, I have never had a problem with LEOs or other drivers.
/ FEL removal - Any tips? #16
My tractor is one of the older tractors (2012 Bobcat CT335) that has the 3rd function valve
mounted on the main upright of the loader frame.
/ FEL removal - Any tips? #17
That seems to be a pain to take off. Where and how do your hydraulic lines disconnect from the tractor? Unscrew the lines at the 3rd function valve and plumb them together? Quick disconnects on the other ends of those lines under the tractor?
/ FEL removal - Any tips? #18
I put a PVC pipe cap over the fitting and hit that with a hammer rather than a rag. It prevents the pressurized oil from going all over the place and minimizes the chance for damaging the nipple.
/ FEL removal - Any tips? #19
I like the pvc cap idea. Rag, cap and bang on loader arm or backhoe platform. I will put a cap in storage box. Thanks.
/ FEL removal - Any tips? #20
The hydraulic lines disconnect from beneath the tractor just behind the step.
The two lift lines go directly to the lift cylinders, and the two curl lines go to
2022 Braxton Creek Freesolo KITCH 18 ft Travel Trailer (A61574)
2022 Braxton Creek...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2016 Jeep Compass AWD SUV (A61574)
2016 Jeep Compass...
UNUSED WOLVERINE QC5-26-20G QUICK COUPLER 5 (A64281)
UNUSED WOLVERINE...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
