OP
Lineman North Florida
Elite Member
- Joined
- May 12, 2008
- Messages
- 2,873
- Location
- LaCrosse Florida
- Tractor
- Farmtrac 360 DTC with FEL & John Deere 5093E with FEL ,Kubota SVL 75-2
1.22"disc blades with 9" spacing. 2. My harrow is adjustable and I have tried it in all configurations. 3. All disc blades are notched. I just completely rebuilt my harrow with all new disc blades and bearings it's a great leveling harrow and if you want to go over the field a half dozen times it will eventually get the ground in decent enough shape that you can plant it, but the one time I borrowed the offset I was able to get it ready with one pass and follow up with the leveling harrow, and that's what I want to be able to do.Throwing out alternative ideas:
1. What is the pan diameter and pan spacing on your "leveling harrow"?
2. Have you experimented with adjusting the front and rear gang angles, individually, on your "leveling harrow"?
3. Are the pans on your "leveling harrow" notched or smooth?
I wonder if an easily adjustable Tandem Disc Harrow with 22" or 24" diameter pans and 9" pan spacing (or 9" spacing nearest the tractor and 7-1/2" spacing in the rear gang, as offered by Monroe Tufline.) might not satisfy your needs and allow you to maintain and store just one implement. These Tandem Disc harrows are 1,600 pounds to 2,700 pounds in weight.
Perhaps you need pan scrapers.....
It is pretty clear following Disc Harrow posts on T-B-N that many, perhaps most, Tandem Disc Harrow owners set both gangs at the most aggressive angles when the Disc Harrow is delivered and never experiment with adjusting the gangs.
I have a Monroe Tuline 9"~7-1/2" spaced Disc Harrow. It has the adjustment holes in the gang lever and is quite fast to adjust; just one pin to remove to adjust the front gang and an identical pin to remove to adjust the rear gang.
TANDEM DISC HARROW ADJUSTMENT LINK: http://www.tractorbynet.com/forums/...ing-three-point-hitch-mounted.html?highlight=
I have the business phone number for Zack Frachiseur, Tufline's SE Field Rep. As Tufline makes both well regarded Tandem and Offset Disc Harrows he would be good for you to speak to. Let me know. I will send you Zacks phone number via Private Message. Zack is a Disc/Offset Harrow pro.
