Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #4,181
/ Let's talk flail mowers #4,182
Mott, along with a few other brands, made flails to run off a front PTO where the flail is out front of the tractor. Generally they were on dedicated mowing tractors. This may have began life as a front mount.
/ Let's talk flail mowers #4,183
Very interesting info guys, much appreciated. This is a pic of my MF 30B, it is 1980's and I have no idea which way the PTO rotates because it not working. Now that I have to rotate all those blades, is now a good time to replace them, I'm just mowing a field, no lawn. I also noticed that the U shaped bracket has a flat side and a side with a curve, do I also need to flip that bracket on the ring. I'm guessing the threads of the bolts need to be facing the back of the cutter blades. Their sure are a lot of mounting holes, I'm hoping the last guy knew which holes to use, because I'm following his selection. Any tips. IMG_1423.JPGIMG_1424.JPGIMG_1425.JPGIMG_1426.JPGIMG_1427.JPG
/ Let's talk flail mowers #4,184
Those scoops look rusty but otherwise fine. If it were me I'd just put them back and mow the field. A few mowings and the surface rust will be worn off.
/ Let's talk flail mowers #4,185
Somewhere back in this thread is a picture of you mower rooter with blade placement. I believe it is a spiral pattern, next knife over is one station below. Online you might fins a parts or operator manual too that will show this. While you have them off touch them up as far as sharpness, but dont get the edge hot by grinding too hard. Hope this helps
/ Let's talk flail mowers #4,186
Agreed, those are mint compared to my knives and my flail cuts pretty darn good in my field.
/ Let's talk flail mowers #4,187
Thanks for everyone's help and ideas. Most of the bolts are pretty bad except for the one in the pictures. Is this just a standard carriage bolt that holds the blades on or does it need to be something special, grade 5 or anything like that. There where no lock washers just a bolt and a nut.
/ Let's talk flail mowers #4,188
I put new knives on my $100 flail as the old ones looked like yours (side slicers though). New knives looked like the old ones within a season. Actually my new knives out at the end of the rotor are noticeably rounded at the end after 2 seasons. Probably should replace em with some of the old ones.
I have yet to see any performance that indicates I should bother sharpening my side slicers.
/ Let's talk flail mowers #4,190
View attachment 500447View attachment 500448
I'd spring for new bolts and nylock nuts. Certainly not grade 8. I don't recall if mine are grade 5 or lower. Never had significant wear on the hanger bolts. Do be careful to get just the right length though. Any threads not protected by the nut will be trashed and
make removal a *****.
/ Let's talk flail mowers #4,192
I stoped by the NewHolland dealer and the bolts are 1-1/4"x3/8" grade 5 with nylon lock nuts, the bolt I took a picture of earlier was only grade 2 and was not the correct bolt. So tomorrow I will change the direction of the blades and see if I can cut some grass.
I see the other bolts do show the threads sticking past the nut and your correct, they are all messed up and don't come off that easy.
I changed the gear oil and it started leaking at the seal, so the previous owner must of had some thick gear oil in there. The NewHolland dealer sold me two quarts of this and said this stuff won't leak.
Leonz, thanks for posting that manual:) and thanks to everyone else who posted, you guys are all very helpful.
/ Let's talk flail mowers #4,193
I did some similar pourable grease in mine with some 90wt mixed in. Filled about half full, about as full as you would for oil, although its a bit hard to tell with thick grease. Worked fine for a season so far. As old & beatup as the mower is i expect the gearbox to outlast the rest of the mower
/ Let's talk flail mowers #4,194
Those of you with gearbox bearing and seal issues, can't these gearboxes be fitted with new bearings and seals at a reasonably low cost? Aren't the bearings and seals readily available from a bearing house or even mail order?
I assume most of the gearboxes call for Hypoid EP gear oil, 80w-90 to 75w-140, GL-5, available most anywhere. My motorcycle uses this oil in the transmission and final drive. I ad a bit of molybdenum disulfide to the gear oil to reduce heat of friction and provide wear reduction.
I'm not a flail owner or user yet but I will be this summer so, I'm bolstering my knowledge base.
/ Let's talk flail mowers #4,195
There is nothing specific to flail gearboxes in regard to leaking or use of grease rather than oil for gearbox lubricant. In fact I'm pretty sure that almost all this information comes from decades of experience with leaking bush hog gearboxes. Not a big deal to use grease. Any lubricant will do. These gearboxes are not fine machinery.
/ Let's talk flail mowers #4,196
Well crap on a stick...the guy with the Alamo flail I linked a bit ago finally got back into town and called me back, turns out it's only an 80". I thought it was at least an 88" and possibly 96", not a big enough upgrade to go from the 68" I sold to an 80". Helluva deal for someone, but not what I'm looking for...I knew somehow it was too good to be true... :rolleyes:
/ Let's talk flail mowers #4,197
Think it through carefully. An 88" would be only a 10% increase. A four hour mowing job with the 80 would take about 3:38 or 22 minutes less with an 88" mower. Compare that to 4:42 minutes with the 68. And, that looks to be a great deal on an 80" top quality mower.
/ Let's talk flail mowers #4,198
Good news...the guy called back after he went out and measured, he was wrong and it is an 88".. Not the 96" I was hoping for, but can't pass that up for the price.. :thumbsup:
/ Let's talk flail mowers #4,199
Yup, generic issue & fix for impliment gearboxes. As far as cheap, it's a matter of perspective. $70 is a lot for seals but isnt isn't to bad compared to an impliment until you consider I paid $100 for the whole flail.
/ Let's talk flail mowers #4,200
Score!! That's about the best deal on a used flail I have heard of. Near new condition 88" Alamo for ?$1600. If he were closer I'd have ditched my trusty Caroni for that one.
2005 Anderson 24ft T/A Dovetail Tag Trailer (A64556)
2005 Anderson 24ft...
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
2020 CATERPILLER 326 EXCAVATOR (A65053)
2020 CATERPILLER...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
