If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #421
No, no problem with the air cleaner.
The air filter on the left side of the cab, for the air conditioner condenser coil, does need to be cleaned when the A/C quits blowing cold air.
We got the 5610 instead of a 5600 after reading about overheating when mowing with a 5600, due to the location of the radiator.
Is your air cleaner on the left side, above the battery, like ours?
   / If you have Toolcat questions, ask them here... #422
I have a G series and the kit is available for $265
   / If you have Toolcat questions, ask them here... #423
A quick question: Hello all, I have a new to me 2013 Toolcat 5600 G series and have ordered an owners manual but it is not here yet. How do I check the hydraulic fluid level? Is there a sight glass or a dipstick? I have purchased some new implements and connected them to purge and fill the empty control lines with fluid. Now I want to make sure I don't need to top off the tank.
Any help appreciated, thanks!
Matt
   / If you have Toolcat questions, ask them here... #424
Matt
   / If you have Toolcat questions, ask them here... #425
With the dump bed up, you can see the hydraulic reservoir sight glass on the black plastic tank, it is aft and inboard of corner of the battery. Note : Lock the dump bed in the up position before sticking your head underneath it for safety.
DEWFPO
   / If you have Toolcat questions, ask them here... #426
If you install the pre-cleaner, your air filter will last a very, very long time. I've got one on mine.
DEWFPO
   / If you have Toolcat questions, ask them here... #427
Pre-cleaner:
   / If you have Toolcat questions, ask them here... #428
I just got a new (to me) 2008 5610. Has anyone put a backhoe attachment on the back? if so which one did you use?
Thanks
   / If you have Toolcat questions, ask them here... #429
I thought the 5610 has a 3 point hitch and a 25hp rear pto?
Do they even make a 3 pt backhoe to mounts on a Toolcat?
I have a 5600 so I defer to some of the 5610 owners here...
   / If you have Toolcat questions, ask them here... #430
It does, I was looking to see if a 3point backhoe attachment would work on it.
   / If you have Toolcat questions, ask them here... #431
It would work and probably bend or break something.
It wouldn't use the PTO.
I had a tractor that weighed just over 6300 pounds and a small 3 point backhoe on it. Using the dipper stick, it would pick up the rear of the tractor and move it forward.
Bobcat doesn't recommend using their SSQA mount backhoes (? Fronthoe?) on a Toolcat.
Bob-Tach(R) Backhoe Attachment – Bobcat Company
Backhoe Attachment - Bobcat Company
   / If you have Toolcat questions, ask them here... #432
I've got a couple of questions regarding my G series 5610. Its time for the 50 hour service and I've got the engine oil changed without issue but can't get the hydraulic filter to budge. Are they really on there that tight or is there a fitting I need to loosen to remove any pressure on the filter? I've read through the service manual and it states to remove the fill cap but that was all.
Thanks
   / If you have Toolcat questions, ask them here... #433
Are you using a filter wrench?
I have read about hammering a large screwdriver through the filter and gaining enough leverage to unscrew it, but haven't done that.
   / If you have Toolcat questions, ask them here... #434
If you can't get a filter wrench on it, put on tight fitting rubber work gloves and wrap the filter with a sheet of any sandpaper and get both hands on it if you can and gorilla it off. I leave the screwdriver thru the filter as a last resort because if it doesn't work (and I've seen that happen only once, and not by me), your equipment is down until you can remove the filter mount and put it in a vice.
DEWFPO
   / If you have Toolcat questions, ask them here... #435
Thanks for the advice. I can get a wrench on it but it won't budge. I guess I'll have to get a little more physical with it.
Thanks again.
   / If you have Toolcat questions, ask them here... #436
I fought with mine with a wrench. I finally won. Good to have a few different types of oil filter wrenches around.
   / If you have Toolcat questions, ask them here... #437
And tubing to slip over the handle to get more leverage. :thumbsup:
   / If you have Toolcat questions, ask them here... #438
On the 2007 model, 50-07 equates to "FPR switch no signal"...so you're right about the Fwd/Park/Rev switch. 33-23 equates to "Main Controller (Bobcat Controller) not programmed". IIRC, the FPR switch is a simple single-pole, multiple-throw switch...so testing might not be too hard. When I had the 50-07 error on my TC, it completely took down the machine. I "fixed" it by going through the wiring harness and insulating wires that had chaffed on the chassis. Sorry...I don't have a clue about the nature of the other error.
I have a 2008 Toolcat that is blowing the FPR fuse when in Park and key on. it seems like a short. Where did you find the chaffed wires on your machine?
   / If you have Toolcat questions, ask them here... #439
Does anyone know the P/N for the Dash Switch for the Rotating Beacon light on the roof?
DEWFPO
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
2017 Versatille 260 (A60462)
2017 Versatille...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A58214)
2014 FORREST RIVER...
1607 (A57192)
1607 (A57192)
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56438)
2014 Doyle Dry...
