If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #421
No, no problem with the air cleaner.
The air filter on the left side of the cab, for the air conditioner condenser coil, does need to be cleaned when the A/C quits blowing cold air.
We got the 5610 instead of a 5600 after reading about overheating when mowing with a 5600, due to the location of the radiator.
Is your air cleaner on the left side, above the battery, like ours?
   / If you have Toolcat questions, ask them here... #422
I have a G series and the kit is available for $265
   / If you have Toolcat questions, ask them here... #423
A quick question: Hello all, I have a new to me 2013 Toolcat 5600 G series and have ordered an owners manual but it is not here yet. How do I check the hydraulic fluid level? Is there a sight glass or a dipstick? I have purchased some new implements and connected them to purge and fill the empty control lines with fluid. Now I want to make sure I don't need to top off the tank.
Any help appreciated, thanks!
Matt
   / If you have Toolcat questions, ask them here... #424
Matt
   / If you have Toolcat questions, ask them here... #425
With the dump bed up, you can see the hydraulic reservoir sight glass on the black plastic tank, it is aft and inboard of corner of the battery. Note : Lock the dump bed in the up position before sticking your head underneath it for safety.
DEWFPO
   / If you have Toolcat questions, ask them here... #426
If you install the pre-cleaner, your air filter will last a very, very long time. I've got one on mine.
DEWFPO
   / If you have Toolcat questions, ask them here... #427
Pre-cleaner:
   / If you have Toolcat questions, ask them here... #428
I just got a new (to me) 2008 5610. Has anyone put a backhoe attachment on the back? if so which one did you use?
Thanks
   / If you have Toolcat questions, ask them here... #429
I thought the 5610 has a 3 point hitch and a 25hp rear pto?
Do they even make a 3 pt backhoe to mounts on a Toolcat?
I have a 5600 so I defer to some of the 5610 owners here...
   / If you have Toolcat questions, ask them here... #430
It does, I was looking to see if a 3point backhoe attachment would work on it.
2013 ISUZU NPR STAKE BODY TRUCK (A59904)
2013 ISUZU NPR...
Bobcat E42 (A60462)
Bobcat E42 (A60462)
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2020 KENWORTH T680...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A56438)
Bulk Lot of NEW...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
