BX25 FUSE BOX Wire Connectors ???
/ BX25 FUSE BOX Wire Connectors ???
So I get what you are trying to do. You will have a neat installation, but couldn't you have done a quick and easy thing like this?
snip
Ahhh grasshoppa'! You have learned how to think like an Artisan!
Alas this EXACT thinking was a miserable failure. This is exactly
what I did, I kid you not, THEN I realized the silly cover will not go on! BLAST!
/ BX25 FUSE BOX Wire Connectors ??? #22
Get this figured out? I put an auxiliary fuse box in my new L4060. Have everything all wired up except for tapping into the OEM fuse box to power the relay with the 60@ fuse up next to the battery. Have the last bit of wire ran & dangling there. Planning on tapping into the 5@ radio wire as that's ignition switched. Really hate to do that cheesy vampire tap again. Hoping somebody has figured out what connector is used so I can pop the existing one out & either do a nice splice, or use the connector itself to crimp both wires.
Get this figured out? snip
Yes,
Fuse boxes and fuse box terminal ends are built out of unobtainium.
Read my details in this thread it explains what I had to do to find
terminal ends. (I found a whole fuse panel for sale w/ all the feed wires
cut on Ebay and used those parts
.) Be sure to take notice of the different
"FEED" terminals, you can have one wire "IN" and 2-3 "OUT" off the one feed wire.
This pic shows the finished product, the cover snaps on OE style now.
/ BX25 FUSE BOX Wire Connectors ??? #24
One of the attachments in an earlier post suggested these were for a VW, Audi and a few other cars. Using this info I found the following that looks like it might work given the open window for the locking detail. Terminals For Micro & Standard Relays 4.8mm Blade
What do you think?
Also found where VW sells short wires with the ends already on. This wouldn't be as clean as buying the terminal and crimping to the wire, but it might be a solution for those who don't mind splicing. Sorry, but I forgot to copy the link.
moship the OE terminals do not have those little ears you see sticking out
on the products you found. If you compare my pictures you will see.
/ BX25 FUSE BOX Wire Connectors ??? #26
The ears could be cut off, pushed in or left alone as they serve no function in the Kubota fuse block. The locking window looks like it might work, but you've studied the details first hand.
Toyota 8BPU15 3,000 LB Electric Forklift (A59228)
Toyota 8BPU15...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
2015 MACK GRANITE GU713 DUMP TRUCK (A59823)
2015 MACK GRANITE...
2025 CFG Industrial QK20R Mini Excavator (A59228)
2025 CFG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
