Yes, you'll want one that can handle the flow without restriction. Not sure if this applies to your older Ford or not, but many tractors devote a certain amount of the flow to the power steering (generally between 2 and 6 GPM). If that is the case, you may be able to get away with one rated for slightly less, but not much.
The specs show a flow rate for the loader with separate flow for steering. The poster is correctly specifying the flow rate according to Tractordata.
I'll look at the larger diverters.
