Tiller Kubota B2601 tiller vs disc
/ Kubota B2601 tiller vs disc #1
bmg7754
Frazeysburg, Ohio
Kubota B2601
Hello,
Long time reader, first time poster. I'm looking to buy a tiller or disc for my Kubota B2601 19.5 PTO HP. 540 RPM. I'll be breaking around 2-3 acres and I'm torn on what to get. A 4-5ft disc or a 4ft tiller...
Any input for my tractor size would be appreciated.
Thanks
/ Kubota B2601 tiller vs disc #2
Welcome! Are you planting a garden or just replanting your yard? What type of soil do you have? Any rocks or roots? The tiller won't like those. The tiller will get the soil more fine per pass, BUT, you will need a super slow low gear. You can go faster with the disk but it will take more passes.
/ Kubota B2601 tiller vs disc #3
You need a PTO powered roto-tiller, assuming you have HST transmission.
To function well as a primary tillage implement, a Disc Harrow needs 22" diameter pans or larger. A B2601 can only pull a Disc Harrow with 18" pans in secondary tillage applications and only under ideal soil conditions.
Go with a PTO powered 48" to 60" roto-tiller for which a B2601 has ample chassis weight and ample horsepower.
LINK: http://www.tractorbynet.com/forums/attachments/308251-disc-harrow-selection-18-45-a.html?highlight=
I'm putting food plots in. Some soil has been turned before other areas are in the woods and this will be the first year ever turned
Thanks! Some of the ground will have a lot of roots and rocks. Virgin soil. Still go with a tiller?
/ Kubota B2601 tiller vs disc #6
Not sure what you are planting. Most seeds only require a minimal depth of tillage. In timber you aren't going to like a PTO tiller. Well, I should say, your PTO tiller isn't going to like timber.
Any type of disc tool will scratch up enough loose soil to cause seeds to germinate and grow.
Back to the first statement, what are you planting?
Between the plots: Winter wheat/medium red clover/white clover/turnips/oats. Small seeds except the oats and rye. Nothing that requires big depth. Also some Egyptian Wheat as a screen.
/ Kubota B2601 tiller vs disc #8
For food plots and that acreage my vote would be for a heavy disc. If you can find a disc were the rear gangs can fold up over the front gangs this will allow cutting deeper on the first passes.
Tillers don't like roots , rocks, long grass, vines, etc..
/ Kubota B2601 tiller vs disc #9
Any disc. Then broadcast the seed. Then drag anything over it to put a bit of cover on the seed. A cattle panel or hog panel with a heavy post or log tied on it makes a great "harrow". :)
Will any disc thats cat 1 work? Or will some connections be too high for my 3pt? I believe my tractor falls in the compact range
/ Kubota B2601 tiller vs disc #11
I'm not familiar with your tractor so can't answer that. Sorry.
/ Kubota B2601 tiller vs disc #12
I have used tillers in tough ground before and would not be concerned about the comments the other posters have made. Living in the Rocky Mountains we have plenty of rocks. With 20 pto hp. I would go for a 48" tiller any day over a 4' disc. Just a better match for your tractor since a tiller pushes forward on the tractor there isn't any draft load.
Large discs behind large tractors work fine, but small tractors can make better use of a tiller.
Appreciate the feedback.
Thanks
/ Kubota B2601 tiller vs disc #14
Yes. A FORWARD ROTATION Tiller, not reverse rotation.
Small seeds require light to germinate. Small seeds like Clover need to be pressed into the soil without cover, or barely covered. You can control the depth a tiller mixes. Till shallow. (A Cultipacker is the specialized Three Point implement used to press seeds into soil.)
Moist woods soil is soft compared to pasture soil which has been compacted by confined hoofed animals.
CULTIPACKER LINK: Google
In the years I have been contributing to T-B-N I have come to appreciate JENKINSPH as one of the three most valued respondents.
PHOTOS: ETA Cultipacker.
/ Kubota B2601 tiller vs disc #15
10/10/2016
Why disc harrow over rototiller for soil prep?
Most game food plot mixes are strong germinators. Till enough so the food plot seeds have a good probability of germinating and becoming sufficiently established before natural vegetation returns.
Rolling in food plot seed with a Cultipacker or roller will improve germination rate considerably.
LINK: http://www.tractorbynet.com/forums/a...tml?highlight=
Your PTO powered roto-tiller is optimum for soil preparation. One pass should be sufficient. Deer seed mixes contain strong germinators. You do not need a perfectly smooth seed bed. Do not roto-till the fertilizer too deep, 2" is deep enough. You want rain to carry nutrients to the root zone, not deeper. Clover has shallow roots.
If the Pure Attraction seed blend has small seed such as Clover, do not drag. Small seeds require light to germinate. If you cover small seeds with a drag, they will not germinate. Dragging is for medium and large seeds. If you want to drag for smoothness and for some tractor seat time, drag after tilling but before seeding.
Seed only when soil is moist or rain is forecast several days in succession.
After sowing seed, roll seeds in if possible. The optimum implement is a heavy Cultipacker, which flattens clods, rolls in seed and presses a pattern into the soil which directs moisture to the seeds and may aid in erosion prevention.
Used Cultipackers are $400-$600. A Cultipacker consists of heavy cast iron wheels on an axle, supported by a frame.
You can buy a cheap poly roller from TSC or another farm/tractor supply store which will last several years, if you empty water before hard freezes. I have used the poly roller in Photo #4 for six years. ((No hard freezes in my part of Florida.))
Or you can press in seed with tractor tires, which will take time over 1.5 acres.
Then, pray for rain, like agriculturalists for 7,000 years. If the soil drys out you will gradually lose some of the seed, which is vulnerable after germinating.
It may take several years to conquer residual weed seeds in recovered ground. You can use 2,4-D herbicide ("Kills broadleaf weeds, not grass") in a one gallon, poly tank hand-sprayer to control any pernicious weeds which sprout amidst your food plot seed. Buy 2,4-D concentrate in the ag chemicals section at TSC or whatever your local farm/tractor store is. Deer will browse many, not all, weeds at some stage of weed growth. The objective is to prevent undesirable vegetation from producing seed.
Disc Harrows and PTO powered roto-tillers are both soil mixing implements which accomplish soil mixing in different ways.
/ Kubota B2601 tiller vs disc #16
I would cut any standing grass,round-up,plow( an inexpensive potato plow) to break the hard-pan and roto-till.Plant and cultipac.In my area anyway the ground is too hard to break with a small tractor and disc.I have tons and tons of rocks of all sizes;just leave the discharge flap wide open.
