Cold cut saw
/ Cold cut saw #22
So if you guys had to pick between a horizontal band saw or a cold saw which would it be? I've been wanting one but haven't bought yet because I can't decide.
It depends on you main uses. I use my vertical/horizontal band saw most for my piddlin, but it is not a precision saw.
/ Cold cut saw #23
I'd mainly just be using the saw for basic fab projects. Nothing super precision but better than a saw-zall or cut off wheel.
/ Cold cut saw #24
In that case I'd get a cold cut saw. IMHO of course.
/ Cold cut saw #25
Yep, these are usually called "Metal Cutting" and get your favorite brand of this style:
/ Cold cut saw #26
I bought a "real" cold saw for only $100! I need to re power it as it has a 3 phase that is usually no problem but it is from Canada and runs on a real high (575) voltage that we do not have here in the US.
Any motor guru's here? I wonder if the motor could be re wound or something.
/ Cold cut saw #27
2abrasive blase in 3 years, I have went thru that many in 1 day. Hated the dust as much as the low wear out time. I bought a 12x8 bandsaw a few years back and my abrasive saw mostly collect dust now.
Yes the dust is terrible and my Dewalt CS with Dewalt blades cut slow I thought, then the 2" pipe has to be put in water and de-burred. Whd you get for a band saw?
/ Cold cut saw #28
I use my horizontal bandsaw for most projects also. However I would NEVER part with my 30+ year old Makita abrasive chop saw.
I keep it (on wheels) out of the way under a bench. Pretty hard to beat for a "quick and dirty" (precision not required) cut. Plus it's great for slotting square and round tube.
Terry
Buy the looks of things, what you need is another drill press...........Tools on wheels is good if you got a place to wheel it, me I'm rounding out of floor space fast, but with 10&14' walls I still have fair amount of air space, my cut-off tool might have be on ropes and pulleys.
/ Cold cut saw #29
I'm leaning towards a HV metal band saw, the cold cut replacement blade I heard is expensive.
/ Cold cut saw #30
Why is that motor so big, maybe theres a smaller one that will fit on that, or you could run a extension cord across the border.
HYDRAULIC TANK WITH COOLING SYSTEM (A60736)
HYDRAULIC TANK...
Land Survey Kit (A60463)
Land Survey Kit...
BUSH HOG 306-6' ROTARY MOWER (A59823)
BUSH HOG 306-6'...
2013 PRATT INDUSTRIES GARDNER DENVER TRIPLEX FRAC PUMP (A60736)
2013 PRATT...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
60'' skid steer bucket (A61567)
60'' skid steer...
