Suitcase weight: is this ok?
/ Suitcase weight: is this ok? #1
Luke'sScreenName
Elite Member
Lakes Region, NH
Kubota MX4800 with BH-90X hoe; Hustler FastTrack 48; B3300SU (sold); 1969 Case 680B CK (sold)
I scored some Case suitcase weights today and want to build a rack for them.
Is it really ok to hang them from some angle iron?
Does not seem like much cast iron holding that weigh while bouncing up and down.
/ Suitcase weight: is this ok? #2
Figure out what they go to and see how they were mounted. All of the weight isn't borne by the angle iron (it could also be a casting) but by pivoting against the bottom of the weight bracket and mostly just retained by the angle iron (or casting). See what the weights were on by searching "tractor weights in Texas" and comparing pics. There is a company there that sells knock off weights and has pictures of most weights. After you find out what they are off of, search the net for pics of weights on that model tractor and the mounting will be displayed. It's OK to hang from angle iron if they can also rest against something.
After a quick check, I'm not sure what they are off. The might be New Holland but might be a mongrel.
Case is what I was told. Lots of pictures of the weights. None of the bracket/rack that I can find. :confused3:
You are suggesting a vertical "bumper" for the weight to rest against? That is what I was tentatively planning...
/ Suitcase weight: is this ok? #4
We've always kept suitcase weights whenever we sold a tractor. Here's a bracket I had to fab up up for the front of a Ford.
1/2"x6" flat bar was used. The weights are 120 pounds each IIRC.
Terry
/ Suitcase weight: is this ok? #5
The one that Big Barn just showed is how it's done. Just like that.
I searched "Case tractor with suitcase weights" images on Bing and your weight showed up maybe 15 rows down.
Did you get a good deal on price?
/ Suitcase weight: is this ok? #6
Head scratching and swear words were also involved. :D
$0.70/lb
I was just worried because of how much metal holds the "hook" part on these weights.
/ Suitcase weight: is this ok? #8
Make a bracket that looks like the one above and it will hold it just fine.
/ Suitcase weight: is this ok? #9
/ Suitcase weight: is this ok? #10
Here's a better picture of the weight on a bracket. It looks like there is a secondary clamp in the bottom angled slot.
Tractor Accessories - BAAH Farm Repair
Very nice find and excellent photo.
That shows a bolt pulling the weight and holding to the bracket. Sometimes there is a solid piece of metal with holes in it and it is long enough to go through all the weights and sometimes it a washer kind of thing that you use individually. Sometimes I don't bolt/clamp them down and I have never had one come off.
/ Suitcase weight: is this ok? #12
Terry
Great example right there!!! That's how I built my weight racks as well. I don't use any bolt mechanism to hold them in place. If you were running your tractor over very rough ground with speed you might want something. Even if just a strong tarp strap making them swing as one.
I incorporated my rack into the factory grill guard base on the Kubota.
/ Suitcase weight: is this ok? #13
On the Ford I had to build the entire grill guard assembly so incorporated a weight rack at the same time. Didn't have any 1/2" thick so used 1/4" and added an additional 1/4x1" flat bar at the top.
Made the slots between the guard uprights the right distance apart to accept weights.
While I was at it I added a hitch receiver. Then built a chain box to fit in the receiver when I'm not carrying a full rack of weights. With the box in place I can still carry two weights if needed.
/ Suitcase weight: is this ok? #14
Richard. Thank you for your time AND your résumé.
You're hired. :)
/ Suitcase weight: is this ok? #15
No, no Terry!!!! No job search here!!!!
I have the best tool possible for projects like these. Time. :D
/ Suitcase weight: is this ok? #16
Me too!
An ex-girlfriend once said I was the "biggest tool" in the shop. In retrospect it may NOT have been a compliment....
/ Suitcase weight: is this ok? #17
Me too!
Sooooo many ways that could have been perceived..... :D
/ Suitcase weight: is this ok? #18
ovrszd--that is a great looking guard on your Ford and the Kubota as well. Clean design and good workmanship is hard to beat.
/ Suitcase weight: is this ok? #19
Thank you for the compliment. I don't post pics to showoff, I post pics to share ideas. I've taken many more ideas from TBN than I've given. :)
/ Suitcase weight: is this ok? #20
I don't think anyone really thinks that. Keep the photos coming.
Otherwise it would be like us still buying Playboy for the "articles".
