Built a quick and dirty thumb.
/ Built a quick and dirty thumb. #11
Nicely done! Will be very handy I'm sure.
/ Built a quick and dirty thumb. #12
I bought the factory thumb and its pretty good but does not open nearly that wide
The ears look to be something I could make but I don't know the name and or type of pivot pin nor do I understand the role of plate (I'm assuming) and nut on the end/outside of the ear.
It's simply a tear drop shaped keeper on the head of the pin it keeps the pin from spinning so the only wear is in the bushings on the arm and not in the mounts on the tractor. I drilled and cross drilled them to be grease able just like the ones on the loader arms. I'll have to pull them out soon to paint I'll take a pic to explain better.
/ Built a quick and dirty thumb. #14
Is the keeper and bushing a purchased item? Is the pin with keeper a purchased item or was that made. It looks like the zerk is recessed- confused how that was done.
No its all made by me kinda hard to explain in words I'll get you an image.
/ Built a quick and dirty thumb. #16
Very nicely done, I will look forward to more pictures...:thumbsup:
/ Built a quick and dirty thumb. #17
Nicely done!!! How are you powering it?
As I recently learned, one restrictor in the ram end hose will slow it to a manageable level. As small as your cylinder is might need to be .030".
WR Long 3rd function kit I knew I wouldn't be happy with anything else.
I have a blank restrictor in my pocket now I was wondering where to start with my hole size.
Drilled it #60 or .040 and man does that seem tiny give it a try and see how it goes I guess.
/ Built a quick and dirty thumb. #20
You are gonna love this tool.
If your drilled hole is too small enlarge it the smallest amount you can each time until you get there. Understanding the flow rate between .040 and .050 for example is significant!!!
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2018 ALLMAND MP40-8BI-PORTABLE DIESEL GENERATOR (A59823)
2018 ALLMAND...
Cat CB24B (A60462)
Cat CB24B (A60462)
LaneShark L53 (A60463)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
