Project Clark forklift
/ Project Clark forklift #1
plastikosmd
Ugh, project Clark
Runs and u just can't kill it
4cyl continental, articulating, 4wd
It has spent its life outside and untouched for years. Time to show it some love
First thing I noted once up, fuel line has a nice near 90 deg kink. Ten bucks says it starts flooding once I fix this
Then a little further up someone used the exhaust pipe to bend the fuel line around a corner, wth?!
Mast bearings need work, should look like this
Got 2 that look like this, empty race with a few balls clanking around
Also I need to replace a solid hydro line in an impossible spot and some seals
/ Project Clark forklift #2
I found those mast bearings on ebay a few years ago for a good price.
I bought this Jewel (???) from a junkyard for $200. about 10 years ago and brought it back to life.
Counter weight, seat and side doors were already scrapped.
It would still lift about 2000 lbs.
I bought another complete one off of CL for $800. and sold the pictured one.
Nice lift!
Did the bearings press onto a shaft/stub? I haven't gotten mast apart to look yet
/ Project Clark forklift #4
It's been a while since I changed them but IIRC they just slipped on and I think there is a snap ring holding them. ???
Here is my replacement Lift.
I got this for $800. It didn't run and had stuck valves and distributor was froze and could not adjust timing.
#4 cylinder is dead but it still has enough power to move on flat ground.
I haven't pulled the head out of fear what I will find and have to go deaper.
Good thing it both run on GAS and have large tires, very hard to find.
Ok thx. Will see when I get the carriage off
/ Project Clark forklift #7
Not saying rust and crud won't have them stuck on, but that's how they should come off.
Aaron Z
Hydro line done, fuel line fixed, greased, now carriage bearings. New ones on order. Using lifts to pick machine as I catch the carriage on a jack
Quick video:
https://youtu.be/7kxSL4QRCTw
Maybe they just need grease? Lol
/ Project Clark forklift #9
I was looking for pics of the bearing mounts when you first posted and came across a post that the bearings are shimmed in or out to take up side play.
The mast where they run is tapered so shims remove the slack.
How bad was the price on the new bearings?
17$ a piecex4
Cheap I thought. I had to guess on the metric equivalent. I had no part # and measured as best as I could based on wear. I'm sure they will work I will update w install
/ Project Clark forklift #11
That's pretty inexpensive for a bearing that hefty. Manuals for forklifts are difficult to find; here is a list of Liberated Manuals, that are government reprints of major brands and therefore are public domain. If you use firefox CTRL-F and search for Clark, it will highlight the relevant lines. There is no rhyme or reason in the listings so a keyword search is the best way to utilize it.
Thk u!
I have both shop and operating manual. The upright is fully covered along w all parts. No carriage!
I did go through it fast and it may be buried out of order. I will check again.
I agree on price. When I first started looking for bearings I didn't use forklift mast in search. Those prices were higher and I couldn't get close to the right size. As soon as I used mast in search terms I got the right shape and sizes.
/ Project Clark forklift #13
That's a good price on those bearings, some places will really stick it to you on bearings.
It's a good idea to keep searching for the right terms and price.
I have found NAPA has listings for the Continental Engine parts also.
/ Project Clark forklift #14
Thk u!
A lot of times the carriage will use the same bearing as the mast sections FYI.. You could call a Clark dealer and get part #'s if you needed to. They would need Model and Serial number of the truck and possibly numbers off the MAST Usually upper side stamped
I had considered that. bearings being the same. The channel size is a bit different as one is captured inside of another inside of another so there is a difference in the OD. ID may be the same. I hope to get the bearings tomorrow and attempt a trial fit on wed
Well, got the worst of the leaks fixed, new battery, new carriage bearings, fuel line, greased, oil changed, weld repair to fork upright, and a broken toe from a minor mishap. Wife could not stop laughing. She said she has a "nervous" laugh. The cat would have been more help getting a bandaid.
Hrm first post got corrupted on Photobucket
Here is repost:
project Clark
/ Project Clark forklift #18
Another tip, I had a 1950 ish Clark (ugly with warehouse hard tires) that had a bad tilt cylinder.
I bought generic cylinder cups from a cylinder shop and punched the needed holes in them with hole punches! worked great.
The cups were about $2.50 each! 4 of them did both sides.
Ok well I picked up some 6' fork extensions from the local scrapyard. 162lbsx0.40$
They need some work. Started cutting out the damage and will weld in patches. I am on the lookout for a fork boom pole too
/ Project Clark forklift #20
Those must have been used on some pretty stubby forks to have that much wear in the middle. I looked for ages to find material to make fork extensions, finally found a couple 7' 4x8 I beams on craigslist and got them for $40, along with a nice chunk of 9x.250 flat bar that I used to extend the tips to 8' and make the bottom plates. True, they're about an inch and a half thicker than proper channel forks, but when you get into that size you're not sticking pallets anyway.
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
3148 (A63117)
3148 (A63117)
2018 CHEVROLET 3500 SILVERADO CREW CAB PICKUP TRUCK (A66091)
2018 CHEVROLET...
FIXED FIFTH WHEEL ATTACHMENT (A68842)
FIXED FIFTH WHEEL...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
