What the Stuck?
/ What the Stuck? #1
mccash40
Adirondacks, NY
kubotabx2360
It was the first warm day of 2017 here in the Adirondacks. A great day for changing filters on my BX23. Drained the oil and started to change the oil filter. It wouldn't budge. It appeared to have swollen a bit and the wrench I had was too small. So it was off to the auto supply to buy a larger wrench at $19. I just about had to crush the filter to get it off and replace it. Next it was on to the transmission filter. No problem...new wrench. Well I used all my strength (I'm 76, so it's not Herculean by any means) and it wouldn't budge. Not only that, I popped a small hole in it and it started to leak. I was parked in the sun, outside of my garage so I started it up and with oil spraying out, I backed it back into the garage and shut it off. Lost about a pint of UDT. This a.m. I called the dealer and told him what happened. I've owned the tractor for 6 years but he remembered me. He said he could send a service man out, but he was coming over my way tomorrow and would give me a hand, no charge. He would also bring some UDT to fill the machine back up. Gotta love these Kubota dealers. I need to find a better wrench, I guess or eat more protein. Anyone else have filter problems on their BXs?
/ What the Stuck? #2
It's not just your BX. It seems like all the factories have a gorilla on staff who installs the filters. I hope that since its 6 years old its not the first time you've changed the filters.
When you get help and get it off make sure to put some oil on the new filter gasket before installing. I'm guessing at the last filter change they were put on dry. If they are put on dry they tend to fuse themselves to the mating surface.
/ What the Stuck? #3
It always amazes me when people on here say that the dealer is not important. :confused3:
Sounds like you have a good one.
/ What the Stuck?
It's the 3rd time for both. A friend showed up as it's a holiday and together we got the filter off and the new one back on. All is well in the North Country. Yes, the dealer is great. Salem Farm Supply, Salem NY.
/ What the Stuck? #5
I hear your problem. I crushed the oil filter at the 50 hour oil/filter change. The two hydraulic filters were easier.......
/ What the Stuck? #6
Mccash, Looks like you are due east of me.
I've had stuck filters too. I've broken filter wrenches, crushed some filters, and drove a large screwdriver through them for leverage to get them off. Maybe you are right about getting older. I know I don't have the strength I used to.
/ What the Stuck? #7
Yes, it has also been my experience - between dry gaskets at install and gray paint on everything, the factory filter installs are tough to break free.
HP
/ What the Stuck? #8
As someone who has broken many a filter wrench, I feel your pain.
I no longer buy the cheap filter wrenches that auto parts stores sell.
Even Snap-On oil filter wrenches break.(No. Snap-On will not exchange your broken tool for a new one)
I use filter wrenches like this one;
Amazon.com: GearWrench 2321 Heavy Duty Oil Filter Wrench (4-1/2 to 5-1/4"): Automotive
Sometimes I use a very long breaker bar with proper extensions & use two hands to break a filter loose.
Always grab the filter at the base & not the tip.
/ What the Stuck? #9
Here Snap On still offers replacement on broken tools. They replaced the guts in a forty year old ratchet just recently.
I too have poked holes through filters or squashed them with a large slip joint pliar. Mostly though because they were in an impossible location. Nothing quite like having old hot oil running down your arm.
I probably put filters on too tight. Just, don't like the thought of one coming loose.
/ What the Stuck? #10
I finally bought one of those GearWrench heavy duty band filter tools. It fits on my 1/2" ratchet and allows the use of both hands - but only in in a convenient location. I've had hot oil down to my elbow - gave up and took a new purchase on the filter. Didn't need hot oil in my arm pit.
My Kubota is the only vehicle I own where the filters are in - more or less - convenient locations. They must have made the design engineers take a shot at filter removal before final location approval. The others are a new adventure in exploration & extraction.
/ What the Stuck? #11
I guess that depends on your ability to sort things out by yourself or with online sources. I bought my tractor from an out of state dealer. Not only did that dealer have the best price I avoided paying sales tax.
/ What the Stuck? #12
A good dealer is a valuable resource but not absolutely essential. Good examples of two different scenarios right in this thread. ;)
/ What the Stuck? #13
+1 !!
I had to take out the steering shaft on my 2004 Chevy Tracker to change the oil filter! Not much easier on my 2012 Suzuki Grand Vitara. On that vehicle, you have to remove the manifold heat shroud and skid plate to get at the filter. With the exception of a stuck filter now and then, they have been a piece of cake to change on all 5 Kubotas I've owned.
/ What the Stuck? #14
When I did my first service on my l3540 (1000 hours, bought it at 950 hours with a brand new motor) I had trouble with one of the filters coming off. Called my dealer and he said to lay into it more, even thought I gave it a hard go from the start. Well I gave it all I had and finally got her off, but I was seeing stars. I remembered that when I put them all back on.
Just south of Albany, NY here, sick of the mud yet?
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63118)
2012 Ford F-150...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63118)
2022 Greenworks...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
2016 POLARIS RANGER 900 UTV (A64047)
2016 POLARIS...
