Planning a custom ballast box
/ Planning a custom ballast box #1
Musdalen
Gold Member
STORY CITY, IA
Ford 8N
S219 has a great thread on http://www.tractorbynet.com/forums/owning-operating/374249-my-new-customized-ballast-box.html. His timing is impeccable for me as I have a new tractor on order (JD 3039 with FEL and grapple) and will be needing to make one as well. And I have somewhat similar ideas, but nothing like his fabrication skills - and I'm a cheap *******.
What I do have is a King Cutter, 3-pt carry all that is rated for 1000 lbs. It looks like this
and it is 36" deep (front to back), and 28" left to right. I too would like to have a receiver hitch on it so I could use it to drag logs and move a horse trailer from time to time.
My thoughts are to cut the two forks shorter by at least a foot. and then having a piece of angle welded between them and probably braced to the back as well. Then deck with treated 2x6's and build a temporary wooden box to fill with lead and concrete. I don't have any metal fabrication skills so I would like to keep the welding work to a minimum as I will have to pay to have it done. but what would you guys suggest for bracing, if any, and any other modifications (maybe some tiedowns on top for my chainsaw and tow chain?).
/ Planning a custom ballast box #2
Easy to deck it with 2x6's and strap a 55 gallon drum on it. Fill the drum with whatever you want.
/ Planning a custom ballast box #3
I needed more weight than a 55 gallon drum would provide so am going a similar route you are considering. Goal is to start at 1050 pounds and work up during testing to 1250 pounds, which I think will be my sweet spot with usage vs. loading tractor on a trailer and having that weight on the back while going up the ramps and removing too much weight from the front tires.
mine is based on a donated 3PH pallet lift I modified to carry a 24" x 48" job site tool box that holds 15 cubic feet. I am ready to test by loading 50# bags of concrete up to my specified weights and see how it goes. Once I get to the proper weight, I will remove the concrete bags, seal the box around the 2" receiver cutouts with ribbon epoxy and then pour the mixed concrete. I figure the box will be about half full and leave the rest for carrying other things. I have lots of onboard tractor tube storage so have no further need of that in this weight box.
_EM51599.JPG_EM51606.JPG_EM51608.JPG_EM51613.JPG_EM51615.JPGDSC00175.JPGDSC00389.JPGDSC00393.JPG
/ Planning a custom ballast box #4
I had a bunch of smaller dimensioned, scrap straight steel lying around and an implement bar like used with a Ford N or Massy TO tractor with the Cat 1 pins integrated into it. So I just tack welded a bunch of that onto the implement bar and slid a couple of 50# wheel weights over it and that worked for me. In the past I have built a form and using a piece of #3 rebar bent in a U shape for a lifting device, just filled it with sacrete. Last one I built was 350#. Course concrete is about half the weight of steel so for small size, go with something in solid steel.
/ Planning a custom ballast box #5
Note I have a 700 LB counter weight plus the carry all. I bet those tires are supporting 5,000 Lbs in the photo Below!
http://www.tractorbynet.com/forums/attachments/327912-custom-3-point-attachment-2-a.html?highlight=
Thanks for some of the suggestions guys. I'm hoping to build something fairly compact because I will be using this out in the timber and in tight places around the barn where small is good. I think I'll have a lot of lead in it along with the concrete.
sdef, I also like that chainsaw scabbard. I have been planning on something like that for certain. I'm tired of carrying my saw in my lap while I drive my 8N in the timber. Looks like yours might be made from PVC pipe? How is it connected to your machine?
/ Planning a custom ballast box #7
What I might do in this case is build a braced plywood box around the carryall frame (once you have it modified to your taste) and then pour concrete/scrap into the box. Size the box to get the weight/volume you need. I bet this would result in a skinny/tall box that would be compact. Be sure to run some bolts with nuts and washers, or j-anchors, from the frame into the interior of the box before pouring, that way your finished block will be securely attached to the frame. The plywood could be removed after pouring, or just left on (may look better with it on).
Oh, and I think you overestimate my fab skills and underestimate my cheapskate tendencies!! Although I did blow the budget on my box just because I had to buy 20' sticks of the square tube and flat bar. Until I use the leftover pieces on other projects, I am definitely over budget on my weight box.
/ Planning a custom ballast box #8
... sdef, I also like that chainsaw scabbard. I have been planning on something like that for certain. I'm tired of carrying my saw in my lap while I drive my 8N in the timber. Looks like yours might be made from PVC pipe? How is it connected to your machine?
Yes, 4" and 6" PVC pipe. Attached with a carriage bolt in two places through the PVC to a square tube framework that is attached to the tractor on the inside and bottom of the square tubing, with the carriage bolts inserted through the inside of the tubes to minimize potential chain saw interference.
If you look carefully between the tubes, you can see the framework- also orange in color. These things work great and mine are always full of chains and various tools. I sized the larger 6" tubes for carrying chain saw bars up to ~ 24" I seem to recall, although mine are 16" and 20". Paint is Binzer primer with Rustoleum finish. I thinned both paints so they would flow smoothly and they came out great. Paint has stayed on the plastic for a tough 2.5 years and 375 hours of work in the woods. Most folks think the tubes are factory installed.
I dug out the old carry all today and stripped it of the mostly rotten wood box on it. Looks like it will work really well for what I want. I can shorten it up from front to back (some serious hacksaw work). I'll put a bottom deck on it with 4x6 treated timbers and then build a reinforced wooden box that is 15" deep, by 30 wide and 30" tall. Total cubic feet will be about 7.8 cf and at 150#/cu filling it with cement will work out to 1170# plus the weight of the carrier frame. Now I just need to find some steel and mounting hardware to make a receiver hitch.
/ Planning a custom ballast box #11
What I do have is a King Cutter, 3-pt carry all that is rated for 1000 lbs. It looks like this and it is 36" deep (front to back), and 28" left to right. I too would like to have a receiver hitch on it so I could use it to drag logs and move a horse trailer from time to time.
What is the advantage, or reason, for cutting the two bottom angle pieces (the forks) a foot shorter???
It was a carrier for my 8N. But the N is going away and a JD 3039R is taking it's place. The JD is rated for 2200 lb
Small, and easier to maneuver in the timber and store under my barn's overhang.
/ Planning a custom ballast box #14
That might be too heavy for a 3039R, but you can know for sure with some math. What's the front loader capacity of the 3039R? What's the distance from the front axle to the approx center of the weight box when it's on the 3 pt hitch?
Loader capacity is 1600#. I don't know the linear dimensions however. Haven't taken delivery yet.
/ Planning a custom ballast box #16
Just using my L3200 dimensions (4' from front axle to bucket, 8.5 feet from front axle to weight box) as an approximation, you wouldn't need more than 750# to fully offset that 1600#. So I'd plan to fill it for 800-900# as a starting point, but leave room for more concrete if you want to go heavier, or have loads way way out in front.
The loader will have more than 1600# capacity down low, so you might want more ballast if you think you'll be exceeding 1600# frequently. However, carrying around that amount of ballast all the rest of the time will probably have drawbacks. So I'd size for a nominal condition.
I doubt I will move 1600# often. I will move bulky stuff (tree carcasses) with a grapple that might be higher and with more leverage than I might really care to tackle without more ballast, but of course, a chainsaw reduces that problem.
I'll think on your estimates a bit and do some arithmetic before I start pouring cement. I want some additional traction I think, so just offsetting a load is not the sole purpose. I still need traction to move it around.
/ Planning a custom ballast box #18
You don't want too much weight back there -- there are some threads about this here where people talk about having too much ballast and some of the issues. So don't overdo it beyond what you need to keep the rear end planted on the ground when the loader is being used.
/ Planning a custom ballast box #19
I have basically the same tractor,, same wheelbase, similar weight,,
except with MUCH larger tires.
Just for grins, I hung an 1,100 pound mower on the back, a couple weeks ago,
The tractor became a sloth
I would not have considered operating it out of low range,
the tractor was MUCH happier when I set the mower on the ground.
That mower will not be used on the JD again.
CADplans, that's an interesting datum to consider. It is considerably more awkward, further back, and unbalanced than what I have planned, but point made. Thanks.
2022 John Deere 6R 130 Tractor (A63111)
2022 John Deere 6R...
JOHN DEERE 1700 - 8R30" VACUUM PLANTERS (A63291)
JOHN DEERE 1700 -...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
Bush Hog 3715 Batwing Rotary Brush Cutter Tractor Attachment (A61572)
Bush Hog 3715...
2022 EZ-GO ELITE...
