Mainfunction Indicator Lamp
/ Mainfunction Indicator Lamp #21
So I got a MIL light today. Tractor was near idle when I noticed it. Tractor had updated software installed at the beginning of January. If I am reading this right, I am ok to run the tractor and no damage should be done?? I need to blow some more snow so I will run the rpms high.
/ Mainfunction Indicator Lamp #22
If the tractor seems to be operating normally, I would try to run it. If you were keeping the RPMs low (below 1,500) that is probably the culprit. If you've followed this thread, you know that after 3 warm-up cycles (not start cycles) the MIL should go out, if there are no additional codes being generated. I didn't know this when mine did this, so I unhooked the battery. That did the trick. Now, I don't operate the tractor below 1.500 ever.
You guys got BURIED! We in CT dodged the bullet that nailed Maine. Yes, I'm sure you have lots more snow to blow. Good luck and post updates!
/ Mainfunction Indicator Lamp #23
Could you clarify warm up cycles please? I ran it hard for about 30 mins then I was done doing my cleanup so I parked it.
Yes we did get a bit of snow. About 2' in 4 days.
/ Mainfunction Indicator Lamp #24
Our 2555 throws a light if we leave it idling for an extended period in a row or don't let it warm up and shut it down and start it and shut it down... etc. We run it at full throttle and get it hot, light goes away.
/ Mainfunction Indicator Lamp #26
When a cold tractor achieves full operational temperature (shown on the temp gauge), that is 1 warm up cycle. If I am not working my tractor very hard, it will be a while before the temp gauge moves.
/ Mainfunction Indicator Lamp #28
I just spoke to my dealer. He confirmed that the MIL light means that the tractor is not meeting emission standards. He said that if the ERG valve sticks for a second, it will trigger the light. He suggested rinsing out the ERG cover. He also said to run it hot. Also, the light on the dash can be cleared by cycling the key three times.
Update: cycling the key 3 times did not clear my light.
/ Mainfunction Indicator Lamp #29
My 2555 has only 34 hours. I have noticed several things that will set the MIL light, mostly operator involved. When I was rewiring stuff in the cab, I turned the key from OFF to START once, and that set the MIL light. Probably because I did not let the computers settle down for a few seconds before START. I usually start it with the throttle at idle. Once started, the computer runs the RPM a little over 1K RPM, then quickly down to 800. I bump this up to about 12-1300 RPM using the throttle [ actually only moving something electronic asking the computer to change the RPM ] and let it run like this for 6-8 minutes while I am getting the front barn door open and me ready to go outside. I then turn the blower on, and slowly move just outside of the barn. I let it run outside for another 5-8 minutes, then command the RPM's up around 1800 and drive the length of my driveway out to the road. At that time, I ask for full RPM, and start blowing. Not allowing the motor to warm up a little before asking for 2000 RPM or so will also set the MIL light. Once the MIL is set, I am only able to get about 2400 RPM and she runs like she does not have a turbo... she is running in limp mode and probably not fully fueled by the computer. The only way to cancel the MIL light is to start and run the tractor three times.... or remove the negative battery cable for a little time. But as long as I give her a little time in the winter to settle down before asking for full speed ahead Scotty, she runs just fine...
/ Mainfunction Indicator Lamp #30
Hey guys I'm new here but have owned a Mahindra tractor for 5 years. My first was a 4010 HST and my second which I just bought last week is a 5555 shuttle. 4010 never gave me any issues but day one the 5555 has issues. My main concern is the MIL light comes on ALL the time and puts it in limp mode. I did everything you guys have suggested like running rpm's up around 2000, started it at idle etc. This is very aggravating that I can't even use the tractor. I don't want to have to stop tractor every thirty minutes to do the idle/run reset 6 times. This new tractor should run at any rpm's with no problems. I do not get the white smoke you guys say you see, the light just comes on at random times. Dealer came out and hooked up his laptop to it and it does show a egr issue. He did the update (again) and said try it but after he left I started running the tractor at 2100 rpm's and after about 15 minutes I looked down and noticed the light on. other times it came on was when I restarted it after I ran it for a while. They are picking up tractor as I type this. Dealer say they don't see any issues with these 5555's and are puzzled. I wish they would just bypass the egr crap but I know that is not happening. I miss the 4010 now but not the small size it was. Sorry guys just had to vent.
Oh yeah the other problem I had was it would not crank after I used bush hog. After a little investigating I found that the PTO switch was sticking on.
/ Mainfunction Indicator Lamp #31
I had the same issues with my new 2555 shuttle. I am lucky we have a very good dealer here. The light came on at .5 hour. I called the dealer right away, the service manager said it is the EGR valve and the fix is to replace it and move its location in the engine compartment. It will not harm the engine in any way . My light has gone out but I will get it in for EGR replacement at first service
/ Mainfunction Indicator Lamp #32
On my 2555, once the MIL light is set, it goes into limp mode and limits the engine power output. [ just like your 5555 ] My tractor still has the factory flash from early last year, and I am waiting for my dealer to get an upgrade EGR kit to put on it. To clear the EGR codes, and shut off the MIL light.... you have to start and run the tractor three full work cycles. Not just start it and run it for a few minutes... shut it off, then start again. The few times I have had it happen, I just put a code reader on it and clear the EGR codes... and that usually shuts the MIL light off. If it does not work, you can unhook the negative battery cable for a few, then that should clear it. Mahindra knows about the problem and has worked out a fix according to what I have heard. They are working on the EGR kits for the 2555, and help is coming. I would contact your dealer on the 5555, and get him in the loop.
/ Mainfunction Indicator Lamp #33
Dealer said they found this issue with EGR plug. Bad spread on pins causing a bad connection. Hope that does it. Dealer has been good to me through this.
/ Mainfunction Indicator Lamp #34
Did they pull the EGR and clean it? My MIL came on after 4 hours... they came out, re-flashed, pulled the EGR and cleaned it. No more MIL's after that and have over 50 hours on it (2555) and letting it warm up @ between 1200 and 1500 RPM.
But my PTO clicking, that is another story. :laughing:
/ Mainfunction Indicator Lamp #35
Don't hold you breath waiting for that kit ! Production is getting those items that make up that kit first. Best thing to do is make sure your dealer uses the updated software and reflashs your ECU.:thumbsup:
/ Mainfunction Indicator Lamp #36
I'm holding mine..... [ gasp... !!!! ] :)
2012 KENWORTH T800 KILL TRUCK (INOPERABLE) (A60736)
2012 KENWORTH T800...
2023 Nissan Altima Sedan (A61569)
2023 Nissan Altima...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
2013 Peterbilt 365 IMT 40/275K6 9.5 Ton Knuckleboom Crane Truck (A60352)
2013 Peterbilt 365...
2025 Swict 84in. Bucket Skid Steer Attachment (A61567)
2025 Swict 84in...
2018 Chevrolet Cruze Sedan (A61569)
2018 Chevrolet...
