BX2370-1 - flat rear tire
/ BX2370-1 - flat rear tire #1
Michael Aos
Gold Member
Colorado Springs
Kubota BX2370-1 RTV500
2016 Kubota BX2370-1. Coming up on about 13hrs.
Got a flat (rear) tire.
I'm planning on having the dealer install Rimguard and adding weights to the rear wheels sooner than later.
Also thinking about purchasing a Land Pride BB1248 48" rear box blade from the same dealer at the same time.
My question is -- should I install something like SLIME / Fix-a-Flat and limp along for a week or two until I can figure out the details (timing, and transporting it to the dealer and back) or just bite the bullet and have them pick it up as-is and deliver it back with the additional weight and box-blade attached?
/ BX2370-1 - flat rear tire #2
I am not sure how the Slime would react with the Rimguard material. Might be a real pain to clean out. I would bite the bullitt and call the dealer to pick up. Did you try adding air to it to see if it will reinflate? Jon
/ BX2370-1 - flat rear tire #3
I wouldn't use the slime, you want a good clean repair before you add rim guard or weights. Why don't you remove the tire/wheel and take it for proper repair at a tire shop or the dealer if he works on tires, then you can make up your mind about when/if you want to add the rim guard; you should be able to move the unweighted tire/wheel around without too much trouble.
Rim guard will give you about 80-90 lbs added per tire. Since you are going to add weights anyways, why don't you try them first. If that gives enough traction/stability you may not need the rim guard. You've already experienced one flat in 13 hours; liquid fill will only make things messy and more costly if you incur a future leak/puncture.
Pulled it off and ran it over to Tire World. $20 to repair "a hole".
I used a 13/16" socket on the lug nuts and torqued them to ~90lbs.
I was expecting them to be 21mm, but the 13/16" seemed to fit better.
Can anyone confirm if these are correct?
I assumed metric for the lug-nuts, but the 13/16th seemed to fit better than 21mm.
I found 80-96 ft/lbs mentioned in a few threads.
/ BX2370-1 - flat rear tire #6
Didn't your tractor come with an owners manual? I would say all questions could be answered there.
/ BX2370-1 - flat rear tire #8
If you got one puncture you may likely get another.
My BX2200 tires rear tires were filled with windshield washer fluid, but after I got my first puncture I had them foam filled. VERY heavy now. Forget how much they weigh. Posted the weight here decade or so ago... memory is short :)
My concern was if I put liquid back in the punctured tire, I would find a way to get another puncture and I did not want to deal with it, so I decided to foam fill the rears. I had already foam filled the fronts.
Just food for thought. Not sure how foam compares in cost to RimGuard. But I will never have to deal with another puncture, and the stability on side slopes is amazing when the mower deck is on the tractor.
Bill
Where / how is that done? I've never heard of that.
Bill
/ BX2370-1 - flat rear tire #10
I had it done at a large tire dealer. I think a place that repairs heavy equipment tires might do it, or could refer you to someone that does in the area.
Not cheap. I think it cost around $120 for each rear tire. I think the tire size is 26-12-12, if I remember right... ten or more years ago.
Bill
2021 SANY SY265C LC LONG REACH EXCAVATOR (A59823)
2021 SANY SY265C...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59906)
2004 INTERNATIONAL...
2014 Volkswagen Jetta Sedan (A59231)
2014 Volkswagen...
Oxy-acetylene Torch and Regulator Rig (A61307)
Oxy-acetylene...
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
