BX2370-1 - flat rear tire
/ BX2370-1 - flat rear tire #1
Michael Aos
Gold Member
Colorado Springs
Kubota BX2370-1 RTV500
2016 Kubota BX2370-1. Coming up on about 13hrs.
Got a flat (rear) tire.
I'm planning on having the dealer install Rimguard and adding weights to the rear wheels sooner than later.
Also thinking about purchasing a Land Pride BB1248 48" rear box blade from the same dealer at the same time.
My question is -- should I install something like SLIME / Fix-a-Flat and limp along for a week or two until I can figure out the details (timing, and transporting it to the dealer and back) or just bite the bullet and have them pick it up as-is and deliver it back with the additional weight and box-blade attached?
/ BX2370-1 - flat rear tire #2
I am not sure how the Slime would react with the Rimguard material. Might be a real pain to clean out. I would bite the bullitt and call the dealer to pick up. Did you try adding air to it to see if it will reinflate? Jon
/ BX2370-1 - flat rear tire #3
I wouldn't use the slime, you want a good clean repair before you add rim guard or weights. Why don't you remove the tire/wheel and take it for proper repair at a tire shop or the dealer if he works on tires, then you can make up your mind about when/if you want to add the rim guard; you should be able to move the unweighted tire/wheel around without too much trouble.
Rim guard will give you about 80-90 lbs added per tire. Since you are going to add weights anyways, why don't you try them first. If that gives enough traction/stability you may not need the rim guard. You've already experienced one flat in 13 hours; liquid fill will only make things messy and more costly if you incur a future leak/puncture.
Pulled it off and ran it over to Tire World. $20 to repair "a hole".
I used a 13/16" socket on the lug nuts and torqued them to ~90lbs.
I was expecting them to be 21mm, but the 13/16" seemed to fit better.
Can anyone confirm if these are correct?
I assumed metric for the lug-nuts, but the 13/16th seemed to fit better than 21mm.
I found 80-96 ft/lbs mentioned in a few threads.
/ BX2370-1 - flat rear tire #6
Didn't your tractor come with an owners manual? I would say all questions could be answered there.
/ BX2370-1 - flat rear tire #8
If you got one puncture you may likely get another.
My BX2200 tires rear tires were filled with windshield washer fluid, but after I got my first puncture I had them foam filled. VERY heavy now. Forget how much they weigh. Posted the weight here decade or so ago... memory is short :)
My concern was if I put liquid back in the punctured tire, I would find a way to get another puncture and I did not want to deal with it, so I decided to foam fill the rears. I had already foam filled the fronts.
Just food for thought. Not sure how foam compares in cost to RimGuard. But I will never have to deal with another puncture, and the stability on side slopes is amazing when the mower deck is on the tractor.
Bill
Where / how is that done? I've never heard of that.
Bill
/ BX2370-1 - flat rear tire #10
I had it done at a large tire dealer. I think a place that repairs heavy equipment tires might do it, or could refer you to someone that does in the area.
Not cheap. I think it cost around $120 for each rear tire. I think the tire size is 26-12-12, if I remember right... ten or more years ago.
Bill
/ BX2370-1 - flat rear tire #11
My dealer convinced me that the minor amount of liquid weight in the tires was a waste of time and money. Recommended that weights be used instead. I made a rack for the QH frame to mount suitcase weights. 50# apiece and only add the weight you need. They also can be used on the front then also. Definitely repair flats by adding tubes. As they went flat (and they will) tubes were installed till all around. Problem with foam is it takes all the flex out of the tires and you cannot soften to float over muddy areas.
Ron
/ BX2370-1 - flat rear tire #12
I got a puncture on one of my rears on my B26 TLB while helping a neighbor repair some roads in their RV park. I hauled my compressor down there and aired it back up and continued to put in air till I finished that job (about 3 days) then when I unloaded it at home, I jacked that tire off the ground using the stabilizers, aired it up to max pressure, soaped it all around till I found the small puncture. I had one of those tubeless tire repair kits and used that to insert a rubber plug. It has been holding good for about a year now. About $4 for the kit and no removing or hauling to a tire shop.
2013 INTERNATIONAL 4300 26FT BOX TRUCK (A59904)
2013 INTERNATIONAL...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
LOAD OUT AND SHIPPING (A61166)
LOAD OUT AND...
WATER TRAILER (A58214)
2014 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1EH765285 (A61165)
2014 International...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
