Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #4,101
I do not own a rear finish mower with 4 gauge wheels,,, yet,,,
I doubt they added them just to increase cost,,,
Remember we are talking about flail mowers not rotary finish mowers. Flail mowers ride on a full length rear roller that takes the place of gauge wheels to keep the mower properly oriented. Rotary mowers don't have rollers so need wheels.
/ Let's talk flail mowers #4,102
Hello, all.
I have been reading and researching (much of this thread) and have decided on a model flail mower that I think will work with the conditions and tractor we have. As mentioned before we run a Swaraj 855 FE (about 50 HP) and the Peruzzo ELK model flail seems like a good fit for us. I'm just curious as to whether the 1600 or 1800 model will be better for our tractor. After thorough checking and a lot of discussion, I am able to report that 100 acres will be our minimum requirement for a flail mowing - at least two full passes per year.
In addition, based on the reading here, I'm thinking the Hammer style blades will be a good choice given the rocky mountain terrain our grass grows on.
Due to the very rural area we're in and the zero chance of finding replacement parts I'm considering including a spare parts package that will last us about 3 years of use (in case of necessary replacement due to damage or wear. If possible please correct me as I'm doing this for the first time!
Spare parts list:
Wheels Accessory for grass cutting
Spare Belts : 9
Spare Hammer Flails : 60
Spare bolts to fix hammer flails : 30
Side anti-wear side skids : 2 kits
PTO shaft : 1
I have found a lot of information on this site and thank all of you for your help and assistance that is much needed!
Thank you.
/ Let's talk flail mowers #4,103
Is 1600 & 1800 the width in mm? That's not quite 6'. I pulled a 7' old Ford 917 with a 32hp (25hp PTO) just fine. Had to go a bit slower, but still cleared an acre an hour in the open.
Not that you'd be able to double my speed, but if you could that's still around 2 weeks to mow that 100 acres. I'd wager more like 3-4 weeks. I'd be looking at a wider mower to cover that ground.
/ Let's talk flail mowers #4,104
Spare parts list:
Spare Belts : 9
PTO shaft : 1
I have flail mowed easily the amount you want to mow for the next three years,,,
and I have replaced nothing.
Hmmm,, maybe only 2 years worth,, but,, surely that spare parts list is way overkill.
/ Let's talk flail mowers #4,105
Hello, all.
Spare parts list:
Spare Belts : 9
PTO shaft : 1
Thank you.
Unless you have some time critical applications, I wouldn't bother with all those spare parts. Just have them shipped UPS when you do need them. I keep one set of spare belts on hand and about a couple dozen knives and a dozen clevises and bolts/locknuts. Definitely do not buy extra "anti wear skids"....if you have those properly adjusted they will last your grandchildren's lifetime. No need for a spare PTO shaft either. PTO shafts are not really wear items.
As I think I've already noted in this thread or a similar one recently, gauge wheels on a flail are pretty much superfluous. I don't have them and have been happy for ten years without. Only a few folks here seem to have them on flails.
If you are running a commercial mowing operation then a few more spare parts might be considered as time is money in that setting. For mowing your own property however there is virtually never a time when a particular mowing job cannot be put off for 3-5 days while UPS gets you your spares.
/ Let's talk flail mowers #4,106
Found a used TM1900 on Facebook tonight going to look at it and probably pick it up tomorrow and save a fee hundred bucks over a new one. Any important things I should check on it before I hand over my cash?
/ Let's talk flail mowers #4,107
Make sure it has been greased. Pull the cover off the belt/pulleys and inspect. You'll probably want to put a new set of Kevlar Gates B43 belts on anyway (check size, pretty sure it is B43 but that is from memory). Belts should be tight with about 1/2" thumb deflection.
If the flail is mounted then have him spin it up. It will shake a bit at start up but should settle down and be reasonably smooth at 2000rpm. When the motor is off, lift the flail high and inspect the rotor and all 28 mounts. Knives and clevises are replaceable/wear items but that rotor is more than half the cost of a new flail to replace so make sure it isn't damaged. The rear roller might be dinged up, no problem, but it should turn easily and not be "banana" shaped. Check to see that the main bearings on the rotor take grease (and ideally look like they have been greased regularly). The rear roller also has zerks on both sides (not so critical). There is also a zerk on top of the secondary drive shaft just near the belt cover. One more under the belt cover for the tension arm that can only be greased by removing it (once a season is adequate). Also check that that PTO drive shaft is greased and in good shape. Finally, just inspect the gearbox oil. Level is not critical so long as there is some on the dipstick. If the mower isn't mounted then make sure all the 3PT mounting hardware is present (just like on any other mower).
/ Let's talk flail mowers #4,108
Lucky to find that one! Used flails are few and far between... I tried to buy a 91" New Holland 918H a few weeks ago but couldn't quite get my price, still might end up with it but right now I've got a serious jones for a 12' batwing... :licking:
I have a Ford 917 flail that I am going to sell. Everything is in good working order. Give me a guestimate on a reasonable asking price.
/ Let's talk flail mowers #4,110
Thanks most of that is obvious I'll definitely check out the rotor for sure and after reading about the early bearing failure from not greasing regular it makes me nervous I don't want something that needs repair right off. He's only 200$ less than new not including tax but said it's less than a year old with little use, supposedly his elderly father bought it and decided he likes a bush hog cut better.
Lucky to find that one! Used flails are few and far between... I tried to buy a 91" New Holland 918H a few weeks ago but couldn't quite get my price, still might end up with it buy right now I've got a serious jones for a 12' batwing... :licking:
Yep the one I ordered should come in this week so I was that close to paying new price and I still might depending on how this one looks.
/ Let's talk flail mowers #4,111
No implement is worth 90% of MSRP or original price after it leaves the showroom much less after a season of use. If I were in your shoes I'd offer 75% at most or pay the extra $500 to AgriSupply just for the peace of mind and warranty.
/ Let's talk flail mowers #4,112
I agree
/ Let's talk flail mowers #4,113
Well that fell through, I typically don't haggle over the phone but for some reason I had a funny feeling about this guy and asked if he had any room to come down and he was stuck solid at 1700$ so I thanked him and went on about my business. The new one should be in by the weekend and I'll go check it out I'm still somewhat up in the air about it as the 8' Caroni RFM is tempting me right on.
/ Let's talk flail mowers #4,114
Doesn't the 8' RFM take about 25% more PTO HP than you have??
Don't let your eyes be bigger than your HP!! :laughing:
I am in the same boat,, I am kinda stuck at looking at 7' RFM's,,,,
/ Let's talk flail mowers #4,115
I wouldn't think that someone considering a Caroni TM1900 flail would also consider a RFM. I think of the Caroni as a field mower that does a better cut than a bush hog but not a suburban lawn cut like a RFM. Finish flails are set up with different types of rotors as I'm sure you know by reading all fifty thousand posts in this thread. I suppose a well kept pasture could be cut with a RFM though so maybe there is room for overlap.
/ Let's talk flail mowers #4,116
What's recommended? 8foot times 5hp per foot is 40hp and I'm right at that considering I'm a gear drive and not HST.
No offence meant but I'm just worried your alittle biased about it all, really concerned being absolutely nobody I know has ever had or seen a flail in operation and I don't want to drop 2k on something I'm going to regret. I do want to mow stuff around the house that can be seen from my recliner so maybe the flail isn't for me it's just hard to say not having ever seen one operate in person. I'm not picky about my lawn however as I drive the truck and tractor on it all the time nearly every day so it's not like I'm talking about a manicured lawn I've never once sprayed it or any such but I will throw a little 34-0-0 on it when I feel like mowing every two days for a month or so.
/ Let's talk flail mowers #4,117
The Caroni flail can give a very nice cut. It isn't like what you'd get with a set of freshly sharpened blades on a good RFM but it is WAY better than what a bush hog can do. I would compare it to what a golf course fairway looks like. Not the rough and not the green. I use my flail to mow around the house and am perfectly happy with the cut but I have absolutely zero pretense of maintaining a ChemLawn perfect yard. Indeed, I cannot tell where the flail section ends and where the Craftsman riding mower section starts as I use the smaller mower right up close to the house and bushes etc. The trick to getting a finish cut with the Caroni is simply to go slow. The mower will cut thigh high field grass quickly but will look a little uneven if you cut fast. If you want the end result to look better than a pasture, you just need to slow down.
Photos below are all from cutting in a field, not a lawn. And, some of it is really low brush or very lush tall grass. I was not going slow.
/ Let's talk flail mowers #4,118
Those pics look great to me I'd be completely satisfied with that finish and that's basically the plan I have in mind for my property, mow the big open areas with the flail and the rest with my little 42" cut Toro zero turn.
/ Let's talk flail mowers #4,119
My flail does pretty much the same.
ALL of my neighbors use 5&6 foot rotary mowers,,, and,,,
they ALL comment about my lack of windrows, and ALWAYS question how to eliminate them..
no one else has popped for a flail,,, yet,,,
One guy switched to using a RFM on a bunch of acres of pasture,, because he had it,,,
BOY, does he go S L O W !!!:eek:
/ Let's talk flail mowers #4,120
One other way to get a "finish" cut with a flail when cutting a knee high field is simply to cut it quickly in one direction and then cross cut at 90 degree angle with the same speed. It basically just double cuts but also mulches better. I don't do that because I don't give a rat's arse about lawn like appearance in the fields that I cut once or twice a season but I have noticed when I recut at 90 degrees that the "hay" gets mulched pretty good.
2013 CHEVROLET 2500 HD (INOPERABLE) (A65643)
2013 CHEVROLET...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A64194)
2006 Ford F-750...
2015 Ford F-150 Pickup Truck (A64556)
2015 Ford F-150...
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
2000 Sterling L9511 Triaxle Dump Truck, VIN # 2FZNNWYB8YAB42893 (A65563)
2000 Sterling...
John Deere 5000-Series Tractor Grill Guard (A65640)
John Deere...
