Gasifier
- Joined
- Jan 22, 2012
- Messages
- 522
- Location
- St. Lawrence River Valley, N.Y.
- Tractor
- 2013 Kubota L5460HSTC
Yes, I have one. I bought it this past summer - installed it myself. In general I like it. Like I mentioned, the adjustment of the boom relief valve made a big difference. From the factory, they were all set at around 3k psi. If you tried to set the boom at one position, and use the other functions to apply force (bucket when prying a rock or root, crowd when lifting, etc), the boom would drop. Bringing that boom relief up to 4k psi made it much stronger, as the boom will now lock into place much better.
Here's a picture lifting an old GM boiler. I would estimate this at 1200 pounds.View attachment 496424
jb1390,
Does your backhoe run off the rear remotes on the tractor? Or do you have dedicated lines for the backhoe that come from up front?
My past tractors, and TLBs, had dedicated lines from up front for the backhoe. I just talked with my dealer and the technician doing the job said some of them do need dedicated lines from up front. But on the 3550s they run right off the remotes.
He said they have a couple of customers who have them like that and they haven't had any problems and one, who he he knows, works the **** out of his.
The technician seems like he is a knowledgeable guy.
I figured I would ask someone else who owns one.
And anyone else out there own a 3550 or 5035 that has a backhoe and can tell me about how yours is hooked up?
Thanks for your time.
