Entry Gate advice appreciated.
   / Entry Gate advice appreciated. #51
I have a swing gate and after 3 Mighty Mule replacements with tenants I gave up.
What happened is people would force the gate just enough to squeeze through and that was enough to bend the worm drive.
Seen some real nice heavy gates but that is for another time and budget.
You need to get the same gates the "Clampetts" had,,,
Even Jethro could not hurt those gates,,, :confused2:
:laughing:
   / Entry Gate advice appreciated. #52
For you folks that use solar for your gates, how is that system? I'm planning on a 16 ft wide slider gate but we do not have power to the end of the drive (1700 ft to the house) so we will be using solar. We live in eastern Ohio so not really an ideal solar area. I'm just kinda worried we will run out of power if opening/closing the gate several times per day.
Thoughts?
We have gone a whole week without sun going in and out several times a day and have never have lost power. A lot would depend on your system, solar panel and battery.
My neighbor has a swing mule and his did not last the sunless week.
   / Entry Gate advice appreciated. #53
Here is the gate I want...
   / Entry Gate advice appreciated. #55
Solar works fine but not with a tiny 5watt panel that usually comes with the gates. A large 30w panel will work fine with a sealed battery.
The problem isn't that it can't power the gate but it doesn't work at night and cloud cover/rain makes a 5w panel nearly useless. You need the extra to cover those times. But with a large panel it will work fine.
I second this...
   / Entry Gate advice appreciated. #56
I did a gate a few years ago and posted about it on here: http://www.tractorbynet.com/forums/projects/290381-driveway-gate-how-questions-challenge-2.html
After a lot of research I ended up with a swing gate 8' high and 14' wide with stone pillars and lights on either side. I went super high end and used FAAC openers and a Linear RE-1 Entry system. The goal was to have something that would last 20 - 30 years with no maintenance, look good and be openable via phone, key code or clicker. In my case I wasn't concerned with security so I did not go with a a lock mechanism, though they're relatively cheap. Some things I learned / considered that might be helpful for you:
- The swing gate is safer than the sliding gate (mine has no pinch points except where the gates meet and the pressure is so minimal it wouldn't injur anyone). A neighbor has a sliding gate and it seems like they had a lot of issues
- The swing gate requires 2 operators (more $$) and power / control lines to each side, so you need to go under the driveway (I had to bore a hole for mine)
- Plan out how you want it to operate, mine ended up way more complex. I had to install a keypad, safety photo eye, safety metal detection loop, a free exit loop (detects cars exiting). All of these cost extra.
- I ended up going with aluminum gates to save on weight. Posts are 4x4 steel set 4' down in concrete. I had to weld gussets on the hinges to prevent bending / flexing. I ended up using an ameristar gate, expensive, but great quality
- If you do columns around the gate I'd make the columns a bit taller than the gate VS level or shorter (huge difference in looks - I had to add height to my columns)
- It's shockingly expensive. Doing it over I may have not done all the automation, costs were over $16k and it turns out virtually no one turns around in my drive now when the gate is open, just a gate deters them even if it's not closed.
For years, I was wanting to create something like this that made a statement, but now I've completely changed direction and want something that is more subtle. I hear a lot of comments that a slider looks industrial, but I don't get that feeling at all. For me, all that matters is that it looks nice when it's all done, and that it works. Keeping it simple is also a big part of it, but no matter what I do, I'm sure it will have it's list of complications.
   / Entry Gate advice appreciated. #58
:laughing:
or maybe one like Batman had it just flops down and stands back up. :cool2:
Just joking, I have a swing gate now but if I have to replace it I think I'll go with a slider.
   / Entry Gate advice appreciated. #59
One of the problems with a slide gate is that it needs to be on a ground track if an automatic opener is used. Every roll gate on tires I've ever seen has been manual open / close because they tend to drift. The most durable track systems are the steel V groove roller that runs on an angle iron on flatbar track. That does a pretty good job at shoving ice, gravel, etc. aside and keep running, but driving over that 1.5" angle iron gets old after awhile.
   / Entry Gate advice appreciated. #60
Ha ha Eddy, yeah I actually saved that wild design gate pic on my phone long ago and found it funny to have popped up here. I think I am in the same boat as you. I wanted a statement gate but now thinking I want something more modern zen design (if that means anything). Simple and pleasing to the eye but practical. Can't wait to see your solution. I really want a slider but I have terrain issues with that.
Roll-off Dumpster With Tires (A49346)
Roll-off Dumpster...
2015 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A49346)
2015 Caterpillar...
UNUSED LANDHONOR ARTICULATING BRUSH CUTTER (A50460)
UNUSED LANDHONOR...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
2013 Mitsubishi Fuso FEC72S Landscape Sprayer Truck (A48081)
2013 Mitsubishi...
New/Unused 20ft x 40ft Container Shelter (A48837)
New/Unused 20ft x...
