Greenhouse ideas
/ Greenhouse ideas #1
aarolar
Augusta Ga
Kubota MX4800
My wife is extremely selfless, I constantly spend money on projects, guns, hunting, tractor parts ect and in the 7 years of our marriage she's been nothing but accepting and giving. Her biggest hobby is growing things she loves orchids and odd stuff like succulents but anyway I digress.
I want to build her a greenhouse in appreciation and I need some advice from the guys at TBN. We don't have tons of spare cash laying around but I'm super handy with tools. My question stems from what material to use on the outer shell of the project, I really would prefer not to use the plastic and I would like whatever I use to be see through and more decorative. Obviously glass would be ideal but I imagine super expensive I'm wondering how the plastic panels would hold up? Lastly do smaller scale greenhouses work properly or is there a minimum size it needs to be to produce the proper greenhouse effect? It will be close enough to the house I can power it for heat and vent fans if that helps.
/ Greenhouse ideas #2
How to Build an Inexpensive Hoop-Style Greenhouse | Alberta Home Gardening
I read this three years ago and was inspired to build one for my wife. I was caught buy how inexpensive this article depicted you could build one for. The one I've built is 12x30 and cost me just over $600. Harbor Freight sells a kit for a greenhouse for about the same price but is smaller than the one I built. My wife doesn't use the house I built for her even though she asked for one for years but I'm using it for my mini farm. I think the HF greenhouse is a good size and price, I probably should have bought one but I enjoyed the entire process of building and assembly of mine. image.jpeg
/ Greenhouse ideas #3
I read this three years ago and was inspired to build one for my wife. I was caught buy how inexpensive this article depicted you could build one for. The one I've built is 12x30 and cost me just over $600. Harbor Freight sells a kit for a greenhouse for about the same price but is smaller than the one I built. My wife doesn't use the house I built for her even though she asked for one for years but I'm using it for my mini farm. I think the HF greenhouse is a good size and price, I probably should have bought one but I enjoyed the entire process of building and assembly of mine.View attachment 498023
I would question the overall strength of such a structure using PVC tubing.
The hooped greenhouse is definitely the most bang for the buck though.
Using two layers of plastic for covering is best, with a small blower keeping the layers inflated.
I would definitely suggest using ONLY steel pipe hoops, unless you want to rebuild after each thunderstorm.
I had a 17' x 50' inflated house greenhouse for many years.
I still have all the pieces, including new cover material.
Wish you lived closer. I would make you a deal that you could likely not refuse.
/ Greenhouse ideas #4
If this is going to be near the house, you probably want something aesthetically pleasing. My "grand plan for a greenhouse" is to use the window panels out of a couple of sets of French doors that I got from a house that was broken into. The door sets are 6' wide, so using both of them would give me a south facing set of windows that are approximately 7' high and 12' wide. The window panels are actually double pane, so I'm debating whether or not I want to completely disassemble them and have 8 panels of single pane glass.
Here's a link that might give you ideas...Google
My point is that you might be able to scour Craigslist or some building supply houses for damaged or "used" doors, windows, etc. that you might be able to use in your project.
Be careful doing something nice like this for your wife. I found out that once you start doing it - they expect you to KEEP doing it! :laughing:
/ Greenhouse ideas
I'm thinking I want to do a barn style house no PVC or hoop style while functional it's not asthetically pleasing at all.
/ Greenhouse ideas #6
Growing season is already starting in GA!!
Maybe you need something to hold you over until the GH goes up?
This is what I use,, translucent plastic barrels, cut in half.
I never have had one blow away!! :thumbsup:
My wife has used them for over 5 years to keep repeatedly starting lettuce.
/ Greenhouse ideas
It never really ended this year honestly been extremely mild this winter...
/ Greenhouse ideas #9
Well now, I'm sure that is asthetically pleasing and while my wife perhaps would have liked one this nice. Mine is in the back pasture away from my home and if the wildlife don't care for its looks oh well. But maybe that's what she means when she says I'm cheap maybe I should remind her that she ain't selfless.
/ Greenhouse ideas
Don't get me wrong now there is nothing wrong with your greenhouse it's just not exactly what I have in mind, if it's in your back pasture do you heat it with gas or not at all?
/ Greenhouse ideas #11
I agree I would want something more aesthetic pleasing if it were planned to be near my home.
/ Greenhouse ideas #12
Are you planning to use ONLY PT lumber?
/ Greenhouse ideas #13
Boy, lots of possibilities... from cheap to expensive, and lots of DIY ideas. Here is a thread on my adventure erecting a Harbor Freight Greenhouse with lots of mods. Added reinforcement, auto water, power, auto ventilation, etc. Might give you some good ideas on what you want in your greenhouse depending on your attendance. I travel for business a lot and sometimes haul the wife along so I try to automate my house and garden as much as possible.
http://www.tractorbynet.com/forums/...eight-greenhouse-construction.html?highlight=
/ Greenhouse ideas #14
Here is the one I am currently building for my wife. It still under construction so there is a mess around it. The greenhouse is 10' front to back and 16 wide. I am putting double doors on the front to get larger items in. I picked this style so that in the future, if wife does not want it,, I can turn it into a nice size garden shed. The plastic has so far witstood winds of close to 100km/h. It may not be aesthetically what you want. I will also be running power to mine for some lighting and a couple of lights. I am going to run water to the building and collect rain water from the roof runoff.
/ Greenhouse ideas
No, from what I read PT lumber is not allowed in a greenhouse the condensation dripping can poison the plants. Plan right now is to lay down a crosstie base then a PT 2x6 bottom plate and build up from there. Bought the crossties and some #3 2x4x12s today for cheap.
Size for now is tenatively 14x10 could change at anytime, tomorrow we set out trying to make our minds up where it will go.
/ Greenhouse ideas #16
If for "esthetic" reasons you use the pine as in the picture, you will be forever fighting rot.
My dad used spruce, and was forever sanding and painting, to keep ahead of the rot.
When he passed, I tore it down, and built a larger, galvanized steel bow house.
Very efficient, with two plastic sheets, and air blown between. Easy to heat, with air between the plastic sheets acting as an insulator.
If you only want a greenhouse for Spring use, then the one pictured will work. Rot will begin to show after a few years though.
/ Greenhouse ideas
Started today got the "foundation" mostly finished. Few more stakes to drive then I can start framing. May do that tomorrow or I may do something else.
/ Greenhouse ideas #18
Hello, walking in late to the discussion... But we build a lot of greenhouse roofs here in the tropics to protect crops from the rain and sun. Galvanized metal is the best material here, I tend to build big gable or shed roofs with 2x2 square tubing, but other people use c-purlins or round tubing also. The hoop houses from round galvanized are popular too but it's difficult to make those big enough to drive a tractor around inside of it. It's nice when you can drive a tractor inside the greenhouse. Wood, bamboo, and pvc all get used but don't last nearly as long as galvanized.
Someone told me that you can make an insulated greenhouse by putting bubble wrap in between 2 layers of film or polycarbonate, and this way you don't need a blower. Sounds like it'd work but never needed to try it here in the tropical climate.
Good luck!
PS
Avoid the duct tape!
/ Greenhouse ideas #19
Any updates aarolar? Interested to see how its coming along. I'd like to start building something similar in size this summer.
/ Greenhouse ideas #20
I love this style, it's perfect. I'm sure plants will grow healthy there!
2017 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A66736)
2017 Ford F-550...
2015 Evinrude G-2 250hp Outboard Boat Motor (A66738)
2015 Evinrude G-2...
2020 KENWORTH K270 S/A GARBAGE TRUCK (A66091)
2020 KENWORTH K270...
2008 SHOP MADE (A67714)
2008 SHOP MADE...
2015 Mercedes-Benz C300 AWD Sedan. (A66738)
2015 Mercedes-Benz...
Unused 2022 Hustler Lift Max LE110 SS Bale Forks and Frame Tractor Loader Attachment (A66734)
Unused 2022...
