Good morning!!!!
   / Good morning!!!! #54,801
Randy hope your mom is ok
48 in paradise this morning high of 58 later today. Mossflower we may get snow if everything lines up right but hard to do in this pattern. Winter for us may be over for this year. Stormy spring followed by very hot summer maybe hotter than last year. Please do not shoot the messenger. Leave tomorrow to head back to salt mines
Kids or children for the most part do not respect their elders anymore
   / Good morning!!!! #54,802
SuperSunday - Go Pats!!!
Ok, I rooted for the Falcons when we lived in Atlanta.
62°F and no rain
Got to make a quick HD run before the game. Can't believe I forgot s grounding connectors.
Be safe
Have a great day
   / Good morning!!!! #54,803
Have you figured out how you want to replace it? Does it cross under the road? Do you have any way of finding out the original plans or origin of it?
Going on the style of drainage tile, that drain has been in a long time. No records, but I do know roughly where a drain comes out on the other side of the track at the bottom of the slope. Now it's clear that it's not just surface runoff and has to my mind undoubtedly been crushed, the railway contractors will also accept it's their machinery that has caused the damage. I will try and get them to dig out for a few yards up and down the slope and replace it - wish me luck !
   / Good morning!!!! #54,804
Kyle, I have been looking at metal emissivity and infra red reflectance, much as you must have been doing for your new roof. In my case I want to make a fire surround for the wood burner in my workshop. It ended up going in very close to the wall behind, so I need a surround that will reflect a lot of radiated heat. As a temporary measure I stood an off cut sheet of galvanised steel behind it. That worked well, although now it's time to make something better looking and certainly more permanent in case a building inspector should want to see in there (the workshop is attached to the house and the house is not yet signed off).
One of the interesting things I came across was that the layer of oxide on the surface of any metal makes quite a difference in the amount of heat absorbed/reflected. Not a problem if you can cover your roof with gold leaf, but a consideration for any other metal. For me, the best material to use looks to be stainless - not too expensive as I only have a small area. 304 stainless would be excellent for a house roof where you want to keep summer heat out, although a little pricey for a house roof.
   / Good morning!!!! #54,805
Prayers for your Mom, Randy
   / Good morning!!!! #54,806
Kyle, Falcons lost SB to Denver, back in late 90's as I recall.
   / Good morning!!!! #54,807
Good luck with your Mom Randy, hope it's just the flu. Which seems to be everywhere right now.
David, only 62? sounds chilly for Hawaii. But then you never seem to get that hot either.
   / Good morning!!!!
I guess that's why its called paradise... Still yucky here. Going to a friends house for a superbowl party :)
   / Good morning!!!! #54,809
From the Eagles, Paradise
"They called it paradise, I don't know why
You call some place paradise, kiss it goodbye"
   / Good morning!!!! #54,811
Eric I believe some serious cold and possible snow is headed your way for the next 10 days or so. Stay warm. 57 here high of 62 tomorrow the winter that wasn't
   / Good morning!!!! #54,812
While you guys freeze your XXXX off Temp today just hit 39.2C . That's 102F in your money :thumbsup:
   / Good morning!!!! #54,814
Mom is better today, a bunch of tests, no answers, but at her age I guess some blips are to be expected.
   / Good morning!!!! #54,815
Randy praying for your mom.
   / Good morning!!!! #54,816
Good evening all. 49F this morning, light wind overcast skies. Saw some sun this afternoon wind light, temp up to 70. Another slow day today, nap 2 days in a row :)
   / Good morning!!!! #54,817
Wow, good football game.
   / Good morning!!!! #54,819
It's just after midnight here in SLC and the temp is 52 degrees. Supposed to get rainy for the next three days with snow in the mountains.
I sure hope this wet weather continues into the spring so my hay fields will produce good. :)
   / Good morning!!!! #54,820
2017-02-06, 0252
27 right now...temperature will be dropping throughout the day to a "high" in the low 20's.
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
KUBOTA SVL97-2 SKID STEER (A60429)
KUBOTA SVL97-2...
pressure washer, and trailer (A56859)
pressure washer...
(APPROX. 20) 4' X...
2019 JOHN DEERE 850L LGP CRAWLER DOZER (A60429)
2019 JOHN DEERE...
5004 (A55851)
5004 (A55851)
