fitterski
Gold Member
- Joined
- Oct 20, 2016
- Messages
- 378
- Location
- Nouvelle, QC
- Tractor
- 1987 Cat-426, 1991 Deutz-Dx-6.05, 2019 Husqvarna 2xHP
Thanks for that summary. Things that come to my mind;
Diesel engines are heavy, and hard to start in cold weather. The older non-electronic diesels seem to be harder to start than the newer electronic diesels. So it looks like you are backing yourself in a corner and not helping your cold weather starting problems very much. .
By migrating off the loader/backhoe I solve the by far worst half of the starting problems. As for the digital/electronic threats to mission-critical reliability I have no doubts ..nor choices. I broke down once in the middle of the road half cleared and it cost me. I had to call a pro but he couldn't get past me so that part had to be done with a little honda, then I had to get towed out to the public road so the rest could be cleared, then I had to get towed back to the house where I had started. $2000, NEVER AGAIN. Once I start engines they must not stop, not even if the Lord cometh to clean things up.
You could put a more powerful gas engine on the unit you have now. It would start easier and be lighter or close to the same weight as the diesel engine you are using now. You said something about you can't change the gearing for a higher rpm gas engine, but could you change just the auger rpm and let the fan turn at the higher speed?.
NocanDo, the fan would turn too fast ui.e. I could only use what I get below 2500 rpm which is why diesels are so great if you wanna do improvised and simple gearing. The gas engines need to run much faster so in any gearing situation they're out in my case. An exception would be for example if I hook up a Triton v10 with a transmission the outshaft of which would be at the same speed as with any other engine gas or diesel. For any hydraulic pump they're not a problem either BUT I will have eyeballed the mechanical setup with engine in place before I get to make that decision. Also I've had a real hard time finding a good Cummins bt6 so that if I can then I will bag it before the weekend. It's raining 24-valve digital engines around here, engines that nobody wants, while real-rod jobs are in VERY high demand (the industry would do well to listen to such rumblings).
I see a lot of problems with the driveshaft running through the cab idea. I see a lot of important stuff in the way, I don't think there is that much room through there. Usually the heater core is on the pass side along with the blower fan, wiring, and you will have to sneak by the inner fender and the radiator. It will be tricky. What if you ran it down the outside of the cab by the pass side door? A piece of channel laying across the frame in the back and another across the front frame rails(ditch the front bumper) with pillow block bearings on the ends for support. That offset would give you plenty of opportunity to gear up or down also.
I'm going to strip the cabin until there's nothing but echo in there. Any drive-shaft passing through beside my own sweet butt would also have to be candystriped but more importantly contained in a 6" pipe 1/4" thick. I can put the rad in lieu of the heater core anywhere else and solve two problems at once while the inner fender can go decorate the neighbour's piano for all I care. But your idea of a side-shaft on the outside is a good one, I certainly would not dismiss it until I get there. It's just all those kinks that I'd have to feel good about. I've also kicked the underneath approach around but then I'd end up coming out the front too low for anything but a 24" fan and I don't really want to get into more lincoln lockers than I have to
