Starting a Stove Fire
   / Starting a Stove Fire #71
I have no doubt your able to start your fires from the bottom. If you've got a better method using dry wood as I mentioned without fire starters or fuel from a bottom up fire how about contributing to the thread so we can learn. I haven't found a better method that drafts as quick with less smoke so clue me in.
There is no best way. It's what works with what you have. That's the clue in.
Contribute; I did, I just stated there are options rather than only one method.
Bottom start fire.
The Lake side fire may have been a little difficult to start with the top down method.
What are the round sections? Is that pine for fire starting?
What's on the camp fire? A big trunk and roots?
As a kid, I used these white blocks (ESBIT?), to fire my toy steam engine. I always loved the smell and wonder what they were comprised of.
   / Starting a Stove Fire #73
The top down method works really well for me, but I no longer bother with alternating directions on the layers or spacing out the splits. I cram as much wood north/south into the stove as will fit, place a handful of splinters and chips on top, wedge a newspaper or packing paper knot on top of that and give it a spark from a lighter. Set the damper down and walk away. Ten minutes later the stove is throwing off great heat and I turn the fans on to circulate it through the house. A lot of it has to do with very dry wood and a great drawing stove. This one is vented to the outside for fresh air, and the flue goes straight up through the ceiling and roof. Draws like a proverbial house afire.
Same here....besides, ounce the cold sets in, my stove very rarely dies...always a good bed of red coals in the morning, reload with wood and go !
I actually have more luck maintaining coals in our fireplace with drafty glass doors and a heatilater, then I do in my rather small airtight (E-W) stove. Just for one thing, the firebox is so small that you can't really jam it up with much wood. I can't put any bigger pieces in there because there is this gas burning arrangement up top that limits height. I CURSE the salesman that insisted I not buy too BIG a stove! Then, when you do get some good amount of ash and embers, you have even less room for wood!
   / Starting a Stove Fire #75
LOL, while I no longer heat primarily with wood I do recall only using about 2 matches per year to heat my home.
There are always some hot coals hiding in there and experienced handling of the controls saves you a lot of matches,
   / Starting a Stove Fire #76
You must have got the same brand as mine:laughing:
In WI I had a 4 cu/ ft fireplace and I could stoke the starch out of it and have nice hot long lasting fires that could overheat the house quickly. We moved to TN a couple years ago and I priced fireplaces and they doubled in ten years.
We have about the same size house but to keep cost down I got a 2 cu/ ft. air tite fireplace with all kinds of tubes in the ceiling of the firebox. Now I need to shovel the ashes out more often and I can only put three 4" or 5" diameter at a time. Once it gets hot though I stick one at a time in and it takes right off.
The bad thing about a short box, I can't stick fire starter then small sticks then bigger sticks then logs to get it going. It won't balance that high. I would bang into the stainless tubes in the top of the firebox.
But it is my fault for being so cheap.
   / Starting a Stove Fire #77
I had one year where I only used 4 matches in 6 months of continuous burn. That was a long winter.... Last year and this year, I've had days where we didn't want a fire because its too warm just from the sun. Crazy weak winters...
   / Starting a Stove Fire #78
Bottom start fire.
View attachment 497283View attachment 497282
Well thanks for pointing out the clue in.
In all seriousness I thought maybe you had a method that worked well as I have the same issues as the op when starting a fire from the bottom with any decent size logs.
   / Starting a Stove Fire #79
Here's a video I took from earlier today.
For the op the key is going to be making sure you have well seasoned wood. One year minimum depending on type of wood and 2-3 years preferred. After that its pretty simple. In the video wood was from a standing dead honeylocust I cut down last week. Bottom row is 9-10" splits. Second row is 5-6" rounds. Third row is 1-2" splits plus kindling from the pile under my log splitter. Used a couple pieces of paper and 1 match.
   / Starting a Stove Fire #80
Have you ever left out the middle bottom piece and put the starter and kindling in there and then wedges above them. I would think you could get it rolling in half the time.
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
2014 Ford Fusion SE Sedan (A55758)
2014 Ford Fusion...
1992 BOBCAT 743 SKID STEER (A52705)
1992 BOBCAT 743...
2015 Ford Escape SUV (A55758)
2015 Ford Escape...
2000 POLARIS MAGNUM 325 4-WHEELER (A51406)
2000 POLARIS...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
