Leaking hydraulic fitting
/ Leaking hydraulic fitting #1
Catman8
Gold Member
California
Massey Ferguson 30B, John Deere 2032R
I have a hydraulic leak and it appears to be wet at the connection or to the right of the connection, any tips to fixing it, I know if it's a threaded connection you take it apart and put more Teflon tape on, but what if it's the fitting. The lines above are dry both directions.
/ Leaking hydraulic fitting #2
BE VERY CAREFUL WITH TEFLON TAPE!
Leave something like the last 3 threads on the end uncovered so you don't get "bits" into the hydraulics. Better yet there are some forms of loctite etc. designed for hydraulics. Hopefully someone else will chime in.
Check the torque.
/ Leaking hydraulic fitting #3
Holy exposed lines Batman! I thought my Kubota's were poorly placed.
/ Leaking hydraulic fitting #8
You might also look to see if some trash has made it's way inside the coupling.
Ronnie
/ Leaking hydraulic fitting #9
This just might be a problem that you come to accept... The hydraulic couplers on my tractors don't leak or seep when under use. They consistently leak with temperature changes; i.e. when it's cold and the metal surfaces contract - I'll have drips in the shed under nearly every group of connectors.
With all 3 machines from 325 hours to 1,500 hours. No matter. And they dripped when brand new...
Of course, I don't park on the concrete driveway in front of the house, either!
Regards.
Update: John Deere came out to my property because the tractor is still under warranty and when he unscrewed the fitting there was a piece of the o-ring missing, someone must of not put oil on the o-ring before they tightened it. A big thanks to everyone who posted on this thread :thumbsup:
/ Leaking hydraulic fitting #11
Regards.
Leaks bug the fire out of me, on the older tractors, i fixed them, with the 96 & 07 model tractors, haven't lost a drop yet, even on the couplers. I'm sure i will at some point & i'll take the time to stop them.
Of course, i'm **** enough to blow debris off equipment at the end of each days work, if i do have a problem, i'm not working on dirty equipment.
Ronnie
/ Leaking hydraulic fitting #12
Ronnie
I can relate... I've got 50' of hose on my vertical air compressor - I know how to use it!
I should have "qualified" my comments with the recognition that every situation is different for each of us. When it's minus 30F here and it stays below zero every night for 3-4 weeks at a stretch; SCV couplers, front differentials at the input-output shafts, will seep.
Hydraulic fluid will freeze and look like crystallized honey.
All has to do with contraction of the metal surfaces with the cold.
/ Leaking hydraulic fitting #13
WHEW, i'd probably leak to at those temps, mid 20's is about as cold as we've seen this winter. I had to replace thermostat housing on the 5303, the past 2 winters it would leak, summer no problems & gasket didn't fix it. So far this winter, no leaks:thumbsup:
Ronnie
/ Leaking hydraulic fitting #14
While I was always careful I was never too worried about teflon tape, then a month ago the little circulation pump on our outdoor wood furnace suddenly got REALLY noisy....When I pulled it apart I found a 3/4" piece of tape blocking part of the impellor.....
/ Leaking hydraulic fitting #15
Also, hydraulic couplers are designed to not leak under pressure. When parked and relaxed they'll seep. I'm OCD about parking with any hydraulics pressurized so I relax the FEL and Grapple if it's attached. When I do that they drip. If I park it with pressure on them they do not drip.
/ Leaking hydraulic fitting #16
And on the flip side, I don't get any leaking from fittings..
WHOLE PART ROOM (A68842)
WHOLE PART ROOM...
20' Container (A64912)
Case IH Farmall 80 (A64911)
Case IH Farmall 80...
2024 HLA MB48 48in. Bucket Skid Steer Attachment (A66734)
2024 HLA MB48...
2019 CHEVROLET TAHOE (A66091)
2019 CHEVROLET...
21ft. T/A Homemade Parade Float Trailer (A66736)
21ft. T/A Homemade...
