scdeerslayer
Gold Member
That sounds interesting. Could you post a picture? With the seat all the way back on my MX5800, there is but a half inch clearance between it and the seat of my BH92 hoe. I could mount a box higher up on the ROPS but modifying it in any way is a bad idea. It opens up a legal can of worms should there ever be a rollover accident.
I made a bolt on bracket to hold a tool box above the right fender of my L3430. It attached to the ROPS using the existing mounting bolts so no modification was necessary. I may try to modify the bracket to fit the MX. I'll post some pics when I get around to it.
I'll try to get some pictures but might be this weekend. As far as the ROPS, some people drill small holes into them and don't worry about it. I mounted a 50 cal ammo box on mine using a properly sized square u bolt to pinch a piece of angle on it. Actually it wasn't properly sized because the legs were too long and I had to use a 1" spacer so I didn't run out of threads. I attached a piece of plate to the angle and mounted the box to the plate. I've got bungee cords and ratchet straps in there, and since the BH takes away the normal mounting place for the SMV sign I mounted one to that box also. I'll get pictures of it also.
