checking hydraulic oil level
/ checking hydraulic oil level #1
Mndigger
duluth Mn
TC5
I thought I posted this once but don't see it. What is the correct procedure for checking the oil level in the hydraulic system. If you screw in the oil fill dipstick you get one level and if you just rest the cap on top without screwing it in, the difference can be half way between the low level and full level.
/ checking hydraulic oil level #2
I check mine with the dip stick screwed in. As long as fluid is in between the low and high marks you are OK. I would expect that in units with larger capacities a little under or over the fill line is acceptable.
/ checking hydraulic oil level #3
You did - up in the Owning & Operating Section.
http://www.tractorbynet.com/forums/owning-operating/374219-terramite-tc5.html
I noticed it wasn't getting much attention there and was going to bump it & suggest posting here but you already have. :thumbsup:
Best of luck with your machine.
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
2023 John Deere Z950R Zero Turn (A63116)
2023 John Deere...
2015 Chevrolet Caprice Sedan (A61569)
2015 Chevrolet...
(2) 18.4-38 SNAP ON DUALS W/HARDWARE (A62131)
(2) 18.4-38 SNAP...
Hustler Super 104 104in. Zero Turn Commercial Mower (A61567)
Hustler Super 104...
New/Unused AGT Industrial Gas-Powered Air Compressor (A61166)
New/Unused AGT...
