exhaust parts...
/ exhaust parts... #1
gravelman
NH
Kubota 2650
Hi folks...gravelman here. i have a 2016 Kubota B2650 the exhaust makes loader arm and area around it all black...would like to get 90 degree elbow to redirect Do you know where i could find exhaust parts, fittings?? Maybe tractor supply has this stuff , not sure. thanks much
/ exhaust parts... #2
They have some sections of exhaust pipe at AutoZone. You can get some of that and experiment. You can also get a section of pipe and have it bent some by a muffler shop. I made a exhaust extension for my L2501 before I got rid of it and got a L3301.
/ exhaust parts...
perfect...thank you very much
/ exhaust parts... #4
You need an accurate measurement of the exhaust pipe diameter before going shopping for an elbow.
Very common problem. Manufacturers just put on enough pipe to get the exhaust away from the tractor's painted surfaces. The FEL isn't considered.
When you resolve this problem take some pictures and start a thread. You know all the other 2650 owners need a fix also. :)
/ exhaust parts...
ok, will do... thanks again
/ exhaust parts...
wow, like that chrome look....
/ exhaust parts... #8
I wasn't really looking for the chrome, but couldn't find 1.5 inch diameter that I needed in a stock finish. Now that it is on, I do like the way it looks.
/ exhaust parts... #9
Any concern with high exhaust temps? Your tractor has a dpf system I think.
/ exhaust parts...
what does dpf system mean... if it that extra emmisions stuff...no it does not have that
/ exhaust parts... #11
I also made a similar mod on my tractor. I measured the OD of my current exhaust and went to a muffler shop and for under $5.00 they came up with this and the clamp.
/ exhaust parts... #12
Kinze KM3000 Monitor (A65640)
Kinze KM3000...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
SARLO (A64557)
SARLO (A64557)
(48) Closing Wheels off Great Plains Planter (A65640)
(48) Closing...
Case HI DMI Ripper (A62613)
Case HI DMI Ripper...
2015 GMC 3500HD Flatbed Truck  6.6L Duramax Diesel (A63689)
2015 GMC 3500HD...
