MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,263
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
This is why I love this forum! :thumbsup:
If one of the diodes is bad in the alternator back feeding voltage to the anti restart relay. Eg the engine already thinks it's running so it doesn't let you"restart" the engine
At first I could not turn the key to the heat position. I torqued down on it and got it to move...the glow plug light came on and it indicated that it preheated. I turned the key back to the start position....nothing. I moved the key back and forth to the heat position several times and it loosened up.
Any suggestions?
For the next time, check around for a good starter/alternator rebuild shop. I'm very fortunate to have one close. Standard rebuild will run less than $75 for anything I've taken him, unless the armature needs replaced. And, normally, is rebuilt and on the counter in 24 hrs. I've taken in a couple when he wasn't real busy, and did it right then, in about 20-25 minutes. I've even exchanged out a couple more common one's he had rebuilt on the shelf.
