Snow tires
/ Snow tires #22
AT3's are not dedicated snow tires, but they're very good all season tires... If they have more than 50% tread, they should be more than adequate.
While I agree that lifting the truck isn't going to help much, if you haven't adjusted the torsion bars for the weight of the plow, it probably should be done, and will pick the front up out of the snow if it's sagged down some due to age and the plow... (Is your truck pretty nose low even with the plow on the ground?)
To adjust front ride height, park the truck where it's good and level, and drop the plow with the blade straight. Now take a tape measure and measure the height of the quadrant at the plow, and then back where it pins to the truck. (The quadrant is what connects to the truck on one end and the plow on the other.)
I suggest setting the ride height so the truck end of the quadrant is about 1/2" higher than the plow end. That seems to work well to keep the blade from tripping easily, and to let it rest fully on the ground when angled. It also maximizes ride height with the plow lifted. Don't be afraid that adjusting the bars well give a "stiff" ride... That's only if you crank them several inches, and the stiff ride comes from having no droop travel. Adjusting the ride height with the bars doesn't change the spring rate AT ALL. (Trust me, I'm a chassis engineer...)
You can go a little higher if you like, but keep the quadrant no more than 1" out of level front to back or it'll trip too easily. (Because the truck ends up pushing down on it instead of forward, and down helps trip the blade...)
4-5 turns of both bolts gains you 1" in ride height, and that's what I add for plows on both 1/2 ton and 3/4 tons. Be sure to turn both bolts an equal amount of turns, and since you live in WI, use copious amounts of schmoolie on the bolts a day or two before you want to make adjustments. Jack the front of the truck up too, so there's less tension on the bars before you try to turn the bolts... Be warned, one of the bolts usually sticks out quite a bit more than the other. DO NOT make them the same. Just turn each bolt the same number of turns.
The snow looks pretty wet in those pictures... Wet snow will get you stuck more easily, but there are several things you can do to help yourself.
Use reasonable tire pressure. I set the fronts at door sticker pressure most of the time. If the truck only plows your drive, or does only infrequent short trips, drop them to 45psi. The rears should be run at not more than 45psi for an empty bed. From there, add 5psi for every 500lbs of cargo you carry. If you're running 70psi in all four tires, they're not able to deform any, and traction suffers greatly. If you never leave your drive, you can easily run the rears at 35psi, and you'll have much improved traction. If you refuse to heed this advice, don't bother reading further, because you're already setting yourself up to fail, and it won't make much difference...
DON'T SPIN!! If the snow is wet, and you spin, it's ice. That fast. If you have really aggressive tires, and there's non-frozen dirt under the snow, spinning might help get down to the dirt, but on previously plowed driveways with some packed snow and ice, spinning just gets you stuck in a hurry.
Use momentum. Don't drive into deep snow, stop, drop the plow, and then try to go. Drop the plow while you're moving. And if you're making a run for the road, don't stop right in the snow the county plow leaves... That crap is really stiff. Blast through. I used to make these runs in reverse, so I was set to drop the plow and head back into the driveway immediately, since I lived on a busy road. That seemed to help a lot and left less snow in the road than driving out forward.
If you find the back of the truck sliding around, put some weight at the tailgate. Start with 500lbs. It makes a HUGE difference. I cut a board to fit the slot in the bed just behind the wheel wells, then toss sandbags or whatever behind the board. That keeps them in place pretty well. Oh I see you have weight... Plenty... :)
Finally, if you're still having issues, get a set of chains for the front. You'll probably have to stick with cable chains on a Silverado, since there isn't much clearance even with 245's, but they'll make a huge difference if the going gets wet or deep.
Hope you find some pointers that are helpful, and not too remedial.
BTW, I do live in NM at the moment, but I spent a LOT of time plowing in Houghton MI (UP) while I was in college, and helping my dad set up his trucks to plow in Northern Michigan. I still have a snow plow for my Jeep, and I'm looking forward to getting some use of it once we've moved to our property in Colorado next winter!!
Chris
(Whew, sorry for the book... That was a lot of info to lay out, and I tend to use too many words... )
/ Snow tires
Chris
Thanks a lot Chris I have about 80psi in all tires I'll drop all to 45 and see how it goes.
/ Snow tires #24
If you just need to clear this snow, drop them to 35psi. :)
/ Snow tires
Good news I plowed all 1/4 Niles of my driveway!. Was back dragging one part but I felt the truck sliding so I plowed straight into the street to the drop off then plowed the rest into the drive that take you into my field. I will be getting snow tires be for more plowing.
/ Snow tires #26
I'm looking at tires for a Tacoma, and the BF Goodrich ALL-TERRAIN T/A KO2 also has the Severe Snow rating. (Duratracs don't come in 245/75x16).
/ Snow tires #27
Remember when you adjust those front torsion bars on a truck suspension, that screws the alignment up and it will chew up the tires if the alignment is way off.
/ Snow tires #28
If you run them at 80psi, you'll be just as screwed... Rock hard tires do not get traction on snow and ice, no matter what the tread pattern looks like. If you like the Coopers, you might check the ATW. It's a winter-biased tread that you can also run in summer without burning it down so fast...
I've also heard (from an engineer at Cooper, no less!) that the BFG ATKO2 is excellent on snow and ice, though not truly a dedicated winter tire. (He said it was the best non-winter tire they'd ever tested on snow and ice... Not counting their ATW, which is semi-dedicated...)
This is true, unless you only crank enough to offset the amount it dropped when you added the plow, then you're just putting it where it was... In the realm of normal ride height, alignment change is pretty minimal, but any time you change ride height from where it was last aligned, you do affect the alignment some. Not much if you keep the change less than an inch, but if you run a lot of highway miles, and alignment is always a good idea, even if you just set toe with a tape measure after adjusting it.
/ Snow tires
I keep it 80psi when I pull my
own trailer and tractor total combined weight 8600lbs. I just have to remember to drop the psi when plowing thank for all the info.
/ Snow tires #30
I would get a load/pressure chart from the tire maker and go by that based on the load on the tires. For me to have 80 psi in my BFG's, I would have to be over gross on the pickup. Even with a 13,000 lb trailer and stuff in the bed to bring it up to max GCWR of 20,500 lb, I would only run 70 psi, and that being in the back set. Fronts would still be 60 psi. When empty, I run 55 psi all the way around. Depending on plow weight, maybe back up to 60 psi on the front. That is all that is needed for max axle gross on the front. Each pickup a little different, but going by load charts from the people who actually make the tires is the best idea.
Rating on the tire is for maximum load on the tire. My commercial truck tires have a max sidewall pressure of 120 psi, but I run about 98 even for max axle gross per the load chart. Got 447,000 miles out of the last set of drive tires on the semi, and have averaged 225,000 miles out of each set of steer tires. I am a very big fan of tire maker load/pressure charts.
/ Snow tires #31
I concur with Copperhead. If you've even just bumped up to the next tire size, that door sticker is probably asking for more pressure than you need, and you should NEVER need 80psi in the front tires...
FWIW, I pull a 10,000lb gooseneck and keep the truck tires at 60psi all around with no worries in the winter. I'd up them to 70psi in the heat of summer, or for extended highway runs, but otherwise there's no problem. But I'm running 255/80R17's, not the stock 245's. Bigger tires take less pressure to handle the same load as a small tire. Running more pressure than you need sacrifices tread life, ride quality, and traction.
/ Snow tires #32
Looking at them for a Tacoma: they have the severe snow rating: All-Terrain T/A KO2 | BFGoodrich Tires.
However like most dedicated winter tires they do not have a UTQG treadwear rating.
2005 DRAGON 130 BBL STEEL VACUUM TRAILER (A65643)
2005 DRAGON 130...
2008 Chrysler Sebring Convertible (A62679)
2008 Chrysler...
2017 Scag SCZ72V Cheetah 72in. Zero Turn Commercial Mower (A64194)
2017 Scag SCZ72V...
2015 GMC Sierra 3500 HD 4x4 Crew Cab Flatbed Truck (A64556)
2015 GMC Sierra...
2026 Electric Tricycle (A64194)
2026 Electric...
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
