Adding a solar charger for the breakaway box
   / Adding a solar charger for the breakaway box #11
The little 1.5w charger HF sells wold be perfect for this application.
Most of these breakaway batteries are sealed lead acid type so there is no electrolyte maintenance possible.
   / Adding a solar charger for the breakaway box #12
I like this project. Thanks for posting.
It's overkill, but in a good way. :thumbsup:
Now you can't build a polebarn to store that trailer in.. bummer.
OK, the little 3A controller came in. Cut the line from the panel down stream from the power poles & made the appropriate connections.
The controller just happens to fit nicely down beside the battery. It was probably redundant, but I don't have to worry about it now...
Nick
   / Adding a solar charger for the breakaway box #14
Nick
Nick, the pix didn't post for some reason
May just be a temporary failure of your DNS to find my images' server. I see them in your quote block ...
Nick
   / Adding a solar charger for the breakaway box #16
Nick
Yep, see em fine now..
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
TANK MANIFOLD (A58214)
2009 Wilson Commander Hopper Bottom (A59814)
2009 Wilson...
