Adding a solar charger for the breakaway box
   / Adding a solar charger for the breakaway box #11
The little 1.5w charger HF sells wold be perfect for this application.
Most of these breakaway batteries are sealed lead acid type so there is no electrolyte maintenance possible.
   / Adding a solar charger for the breakaway box #12
I like this project. Thanks for posting.
It's overkill, but in a good way. :thumbsup:
Now you can't build a polebarn to store that trailer in.. bummer.
OK, the little 3A controller came in. Cut the line from the panel down stream from the power poles & made the appropriate connections.
The controller just happens to fit nicely down beside the battery. It was probably redundant, but I don't have to worry about it now...
Nick
   / Adding a solar charger for the breakaway box #14
Nick
Nick, the pix didn't post for some reason
May just be a temporary failure of your DNS to find my images' server. I see them in your quote block ...
Nick
   / Adding a solar charger for the breakaway box #16
Nick
Yep, see em fine now..
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2016 Ford Explorer 4WD XLT SUV (A59231)
2016 Ford Explorer...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
KOMATSU PC228USLC-3 EXCAVATOR (A60429)
KOMATSU...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
