Welding up a toothbar
/ Welding up a toothbar #1
aarolar
Augusta Ga
Kubota MX4800
Working on fabbing up my tooth bar and I'm wondering which way the teeth go on when I get finished, it's not super obvious they fit equally well both ways.
/ Welding up a toothbar #6
Those come from titian which is where I got mine from I would order direct and cut out the middle man excellent folks to deal with.
That looks like it is direct from Titan. "Ships from and sold by Titan Distributors"
They are just using Amazon as a store front and are selling the same products there as their own website and for the same price. Plus your get free shipping.:thumbsup:
/ Welding up a toothbar #7
Definitely the one on the far end.
Look at the one closest to the camera. If you sat the bucket flat on the ground and tried to skim the teeth would be gouging all the time. You would NOT like that!!!! :)
Got free shipping direct from them too
Yep got welded up and teeth installed I'll post a pic later.
/ Welding up a toothbar #10
Looking forward to the pics.
/ Welding up a toothbar #12
Looks good - nice job. I bet you like the way they improve your bucket and cutting edge capabilities. :thumbsup:
gg
gg
You better believe, I never ran this one without teeth but I have ran another loader tractor extensively without teeth and wow what a difference.
/ Welding up a toothbar #14
I'm kind of surprised doing the following is not more popular.
What I found is really durable and not prone to catching material in the bucket is to Buy an extra cutting edge for when you want a flat edge, and weld on ESCO Ultralokョ Teeth.
They are really premium quality teeth, and a snap to replace.
ESCO Corporation |
Ultralok(R) Tooth System
Theses people will help with sizing and have decent prices.
Bucket Teeth For Excavator, Backhoe, Bulldozer, Skid Steer
Only 11 Plow bolts hold my edge on and I used:
Plow Bolts | Grade 8 Plow Bolts | Grade 8 Plow Bolts - GlobalIndustrial.com
If I want a flat edge it is not hard to change over, however with a 2x2 x1/2" angle with bolt on cutting edge on the back of my bucket, I use that for quick back dragging and grading.
/ Welding up a toothbar #15
Nice modification!!!
Just remember you have totally altered the bucket. It isn't built for the stresses that can be put on it now. Keep that in mind as your use increases. Forgetting this will end in having a bucket with a smile. :(
I can fix that too
/ Welding up a toothbar #17
Yes very nice and nice welds too! Amazing what teeth can do for a bucket and digging. :thumbsup:
/ Welding up a toothbar #18
I'm taking your advice. Ordered the same teeth... thanks! Can you please tell me what size your flat stock is? I'll have to locate a steel dealer around here. Well done BTW!
/ Welding up a toothbar #19
I got the same Titan weld kit. The flat stock is 4 inches wide by a half inch thick. It was a fairly hard alloy. I tried band sawing it but switched to a grinder cut off wheel after ruining the blade. Lots of orange sparks.
/ Welding up a toothbar #20
Thanks! I'll go find that stock and grab a few new cut-off wheels. Those teeth are due in today from Titan direct. I bought two bolts and two cobalt bits to drill the holes. So much cheaper to DIY. I got two sets of 5 but will only use 8 of them evenly spaced. That leaves me two spares in case I break one.
2026 KH72 72in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A66734)
2026 KH72 72in...
Titan MI 3106 (A64911)
ALLMAND ECOLED-RIG SPEC LIGHT PLANT (A68842)
ALLMAND ECOLED-RIG...
2027 . . (A67714)
2027 . . (A67714)
2023 Kubota M5-091D 4WD 92HP Utility Loader Tractor (A66734)
2023 Kubota...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
