3pt limiter chain
/ 3pt limiter chain #1
aarolar
Augusta Ga
Kubota MX4800
What's the general concensus concerning the use of 3pt limiter chains with a ballast for loader use? Thinking it would be good to get the load off the hydraulics or does it not matter?
/ 3pt limiter chain #2
I see no need for anything like that.
/ 3pt limiter chain #3
Doesn't matter. The 3pt is designed to carry heavy loads for extended periods of time. I wouldn't worry about it.
/ 3pt limiter chain #4
Chains are mostly for maintaining a set height with no drifting lower, but still able to lift.
Bruce
/ 3pt limiter chain #5
Bruce
Or for restricting upward movement of the 3pt beyond a certain point. :)
/ 3pt limiter chain #6
Your putting a lot of extra stress on that one point. Thy hydraulics were built to support the weight.
/ 3pt limiter chain #7
Good point. Missed that one. With the chains pictured the vertical stress is transferred from the lower 3pt arms to the top link bracket, which is designed to handle horizontal stresses. :)
/ 3pt limiter chain
I was thinking that too don't seem like a good way to load the top link bracket just figured I'd ask and see what the general thought was I saw someone on here recommend this at some point.
/ 3pt limiter chain #9
Various operators have various needs.
Don't worry about carrying long term loads on your 3pt. :)
/ 3pt limiter chain #10
Those chains look like they are on an 8N Ford. I use them on mine because the 3 point hitch raises and lowers (slightly) depending on the engine RPM's. If you are using a mower and trying to maintain cutting height with the 3 point you will constantly be adjusting slightly up and down depending on the load to the engine. With chains you set the mower height with them and drop the 3 point all the way to have the same cutting height and still allow to quickly pick up the mower if you run over something sticking up.
/ 3pt limiter chain #11
I had them on my old TO-20 to keep the mower from swinging sideways and rubbing on the rear tires. If you fave clearance issues they can help.
/ 3pt limiter chain #12
I'd be worried about breaking that top link bracket. If it was several times that size I wouldn't worry, but thats the kind of part you can't easily fix, and would be expensive to replace (the whole housing).
The 3pt is made to handle heavy weights, just don't shut it down for extended periods of time with the 3pt raised and it won't be a problem.
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
2016 Ford F-550 4x4 Venturo ET25KXX 2 Ton Crane Service Truck (A61573)
2016 Ford F-550...
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
60" EXCAVATOR RAKE (A64279)
60" EXCAVATOR RAKE...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
