The Largest Diameter (29") Dead Tree That I Have Pushed Over
   / The Largest Diameter (29") Dead Tree That I Have Pushed Over #1
Xfaxman
Super Star Member
Guthrie, OK
Toolcat 5610 G - Bobcat V417 - TORO+Loader
Measured the 91 inch circumference right below the branches. Tree has been dead for about a year, the bark is starting to fall off.
Extended the boom, breaking the roots.
Lifted and pushed it back, then knocked off as much dirt as possible.
Found the balance point and took it to the burn pile, on the stump bucket.
   / The Largest Diameter (29") Dead Tree That I Have Pushed Over #2
That shot from behind where you found the balance point reminds me of an ant hauling off a dead grasshopper.... something 5 times its size.
Looks like fun! :thumbsup:
Yep, a hard working ant. :D
Made it without falling off! :thumbsup:
The brush pile 2 days later, in the daylight.
   / The Largest Diameter (29") Dead Tree That I Have Pushed Over #5
Impressive balancing skills indeed. I would have been tempted to go get the grapple back on after digging up the roots.
I guess a narrow, no lid grapple did the trick here! :D
   / The Largest Diameter (29") Dead Tree That I Have Pushed Over #6
I'm seeing 6-7 cuts with the chainsaw and just as many trips with my little PT425. :D
And the stump would have stayed where it was, too! :laughing:
Yep, took three attempts to balance it. I started too far away from the root ball.
I have carried a lot of smaller trees on the stump bucket and never had one fall off. It helps that the front axle is bolted to the frame and the rear axle pivots.
Even with the narrow 44" grapple, I balance the tree and leave the lid open. :thumbsup:
   / The Largest Diameter (29") Dead Tree That I Have Pushed Over #9
I need some fire wood,
   / The Largest Diameter (29") Dead Tree That I Have Pushed Over #10
You need a wood stove!
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2014 Ford Explorer AWD SUV (A59231)
2014 Ford Explorer...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
CAT 336E (A58214)
CAT 336E (A58214)
Tanker Trailer (A59230)
Tanker Trailer...
2844 (A58376)
2844 (A58376)
