rockyroadnz
- Joined
- Nov 25, 2008
- Messages
- 15
- Location
- Pauatahanui, New Zealand
- Tractor
- Belarus 572 4WD, Yanmar B22 digger, Kubota B7100HST
Tipping / dump trailer. Will this hydraulic ram set up work?
Hi, I am building a tipping trailer to use behind my tractor, using some recycled parts to minimise cost. I have got the trailer and tipping deck built but before building too much steel work for the ram I wonder if anyone can tell me whether this will work. I have read lots of forum posts and tried to figure out some of the spreadsheets others have posted, but the angles and calculations do not make sense to me.
I have attached a diagram at the bottom of this text showing what I plan, and listed what I think are the key facts here.
The tipping deck is 3.5 metres (11ft 6in) long, and the hinge point will be 0.6 metre (2ft) from the back.
The all up weight of the tipping deck and its load will be 2500kg (5500lbs). Assuming it is a pile of dirt on the deck I suppose most of the weight will be forward of the hinge point. i.e. the ram will have to lift pretty much all of the weight because very little weight will be on the overhang.
The ram I have is 1.180 metres (46.5 in) retracted and 1.95 metres (76.75 in) extended.
The ram is 92mm (3.6in) ID. I cannot actually measure the ram inside diameter because the ram is assembled but OD less a generous allowance for wall thickness gives me 92mm (3.6in) ID
I can mount the ram bottom hinge centre 0.35 metres (14 in) horizontally below where the ram is attached to the tipping deck. I might even be able to stretch that to 0.4 metres (15.75in).
The manual for my tractor says it produces 160KGF/CM2 (2250 psi) at 40 litres per minute (11GPM)
With the tractor producing 160KGF/CM2 (2250 psi) will that be enough for the ram to tip the deck?
Thanks in advance for any advice.
BTW. I hope I have picked the right forum for this question. There were a few to choose from.
