drizler
- Joined
- Jul 27, 2007
- Messages
- 743
Should be a book , white full size operating manual as well as one for the loader. Look in compartment behind the seat
Picked up my 1736 today. Does anyone know if a digital copy of the manual exists? Mine did not come with a manual. I am going to contact the dealer Monday but I would rather not have to wait a few days to do some reading up on it.
Second, the tractor seem to make quite a bit of noise from the rear end under tight turning. Is that normal?
Right, the box behind the seat is empty.
Did any of you figure out how to change the meter from Kph to Mph?
That is a nice reference point to have established!Down around zero (deg F) here and we had some snow so I decided to fire up my 1736. No issues at all, just turned the key, waited for teh glow plug indicator to go out and it fired right up. It's in a non heated steal shed and has no block heater or plug in. It hadn't been started for probably 2 weeks so it was at full cold soak. Hopefully it keeps starting this well....
LM
I have yet to start my 1736 when it was much cooler than +15 degrees (F) and at that I used its block heater for 1-2 hours before I turned the key.
Oh my, you da man.Going to be negative teens below zero in the next couple of days so I'll get another reference point.
LM
Has anyone added the 3rd function on the loader? If so, what was the cost? And, how do you like it? I'm speaking of the change where the control lever on the loader is replaced with a new one with a switch and the bucket tip channel is then diverted electronically through solenoids to remotes.
Thanks,
LM
. Going to be negative teens below zero in the next couple of days so I'll get another reference point.
LM
Was about -15 deg the other day and I went out at about 10am to fire up the 1736. By this time is had warmed up to just below 0 deg F, and it had been below zero for a few days so the tractor had sat in the unheated pole shed for a week+ without running so it was cold soaked pretty well. I hit the key, the glow plugs cycled and it started. It ran pretty rough for about a minute and I let it run for 15-20 minutes before moving it or working it. I think this is about the threshold on where it would start without some outside heat applied.
LM
Got the tractor back after 3 days and a new tank sending unit, gauge read 3/4 tank and after it when down to empty and was re-fueled it was stuck at one bar once again, dealer said he would look at tractor again, an interesting observation from service people is tank did not need to be dropped, apparently under the running board or foot rest there is an inspection plate to access tank and sending unit, so they say..
