Winch hook up help
/ Winch hook up help #1
dieselkelly
West Luther, Ontario
arctic cat diesel 700 atv
I just got my warn winch back from servicing. I have hooked it up twicw before. It's pretty straight forward, blue to blue and yellow to yellow.
Before I attachd the bolts , I hooked it up and tried it, it sounded like it was "spooling".
Then I secured the bolts. When I had a helper come out to verify that it was turning all we heard was "click", "click" when I pressed the rocker switch. I undid and re- attached the contacts again but now it won' t turn? Only the clicking noise.
Help, it's snowing like mad and we need the plow to work.
Thanks!
/ Winch hook up help #2
Thanks!
Unless you have bad power or a bad connection to the battery somewhere it sounds like it may be a bad solenoid contact. Or maybe your service guy didn't get all the connections as tight as he should have. Think like you're troubleshooting a bad starter.
Thanks. I just spoke to the shop and they confirmed exactly what you said. Solenoid. Sadly, we are buried in 3' of snow and we use it to plow. I sure wish the shop had fixed it if they saw it wasn't working. We just paid them extra to deliver it yesterday.
Thanks for your reply.
/ Winch hook up help #4
Not sure what they repaired on the winch but apparently they didn't test it before returning it. I'd give them a call back and tell them you remounted it and it doesn't work. Unless your solenoid is separate from the winch, then you'll need to replace it.
/ Winch hook up help #5
One would think they should have fixed it. What did you pay for? Time for them to step up to the plate and make things right PDQ.
2020 FORD F-550 CAB AND CHASSIS (A65643)
2020 FORD F-550...
2018 FREIGHTLINER CASCADIA  125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 FREIGHTLINER...
New/Unused ATS 80 Gallon Two Stage Air Compressor (A65583)
New/Unused ATS 80...
Brady 512 Feed Wagon (A66408)
Brady 512 Feed...
2023 CHEVROLET 3500HD TRUCK (A63276)
2023 CHEVROLET...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
