Winch hook up help
/ Winch hook up help #1
dieselkelly
West Luther, Ontario
arctic cat diesel 700 atv
I just got my warn winch back from servicing. I have hooked it up twicw before. It's pretty straight forward, blue to blue and yellow to yellow.
Before I attachd the bolts , I hooked it up and tried it, it sounded like it was "spooling".
Then I secured the bolts. When I had a helper come out to verify that it was turning all we heard was "click", "click" when I pressed the rocker switch. I undid and re- attached the contacts again but now it won' t turn? Only the clicking noise.
Help, it's snowing like mad and we need the plow to work.
Thanks!
/ Winch hook up help #2
Thanks!
Unless you have bad power or a bad connection to the battery somewhere it sounds like it may be a bad solenoid contact. Or maybe your service guy didn't get all the connections as tight as he should have. Think like you're troubleshooting a bad starter.
Thanks. I just spoke to the shop and they confirmed exactly what you said. Solenoid. Sadly, we are buried in 3' of snow and we use it to plow. I sure wish the shop had fixed it if they saw it wasn't working. We just paid them extra to deliver it yesterday.
Thanks for your reply.
/ Winch hook up help #4
Not sure what they repaired on the winch but apparently they didn't test it before returning it. I'd give them a call back and tell them you remounted it and it doesn't work. Unless your solenoid is separate from the winch, then you'll need to replace it.
/ Winch hook up help #5
One would think they should have fixed it. What did you pay for? Time for them to step up to the plate and make things right PDQ.
2016 TAKEUCHI TB240 EXCAVATOR (A65053)
2016 TAKEUCHI...
Toro Reelmaster 4000 D Mower (A65579)
Toro Reelmaster...
John Deere BW17029 Tractor Bucket (A65640)
John Deere BW17029...
7ft Metal Texaco Pump (A65583)
7ft Metal Texaco...
Kinze KPM3 Planter Monitor (A65640)
Kinze KPM3 Planter...
2006 HEIL 200BBL CRUDE TANKER (A65643)
2006 HEIL 200BBL...
