New L2501 seems really loud! Suggestions?
/ New L2501 seems really loud! Suggestions?
/ New L2501 seems really loud! Suggestions? #42
Well I have the opportunity to trade up to a L3301. So what's ya'lls opinion.... spend another $3,000 and get a L3301 which is quieter or keep the L2501?
If I keep the L2501 I will have to do something with the exhaust. Possibly install a L3830 muffler.
The other issue is the L2501 really stinks... smells like a Ford diesel truck if you are familiar with those. Blah. Not sure if that will go away after it breaks in or not. When running at night you can see a fog of exhaust going past the headlights.
What would you do?
I would look at a different muffler if that solves the dB issue rather than going and getting a different tractor which could have its own "concerns". Gotta learn to like the smell of diesel :D
/ New L2501 seems really loud! Suggestions? #43
What would you do?
My question for you would be do you need more tractor? If so why? Is the 3301 a big enough step up is you do need more tractor? If you are not happy with your tractor and want a newer and nicer tractor I say go for it if it makes you happier, if you need a bigger tractor I would jump bigger, nobody said there tractor is too big lol, well I guess if you want to mow your yard with a duelly 150hp tractor, That might be a bit excessive lol.
/ New L2501 seems really loud! Suggestions? #44
Well I just got a new L2501 with front loader and backhoe. The engine seems really loud! The exhaust has a metallic rattle sound to it. My L3830 is much quieter sounding.
Using a dosimeter app on my phone I measured around 92 db at 1700 RPM. My L3830 is running around 90 db. The L2501 has a harsh exhaust note like a hammer hitting an anvil.
I'm curious if anyone else thinks their L2501, L3301, or L3901 is loud. I'm planning to drive another L2501 at dealer when I head down
there.
One thing to note. The tractor has off-road diesel in it. Not sure if that would make it run louder or not.
I've attached a pic of my two Kubota since we all like pics!
I'm a certified Shade Tree Mechanic... and I am certain that the noise level of the tractor in the YouTube video is WAY louder than it should be. To me, it sounds like an exhaust manifold leak. I'd check that possibility first. If not that, I'd be having the dealer investigate it.
/ New L2501 seems really loud! Suggestions? #45
I'd only go with a 3301 if you are ready/willing to accept the Tier IV Final claptrap. While the 3301/3901 haven't had as many issues as other models with DPF, I'd still avoid them if I had the choice. There's a reason the 2501 is so appealing and sells so well.
Edit to add: while the 3301 sounds a lot quieter in the video, I don't think the 2501 video sounds abnormally loud. It sounds like my L3200 and L3800 models I have driven, which sounded like the previous L2800/3400 models. I think this is just a matter of the 3301's more restrictive exhaust plumbing acting like more muffler.
I'd be tempted to look into re-routing the exhaust exit on the L2501 or changing to a bigger muffler. Before doing that, try to determine how much of the noise is exhaust noise versus general engine noise. Exhaust noise will pretty much be focused on what comes out the tailpipe.
Yeah I agree. It sounds way too loud.
I've run a lot of Kubota Diesels and this little bugger is by far the loudest. I fired it up this morning.... pumps out that sickening Diesel smell (no other Kubota I have run makes that smell) and is loud as H3LL!
It's getting loaded back on trailer this afternoon and headed back to dealer. Going to get the L3301.
When you were driving your tractors did it seem like it was loud enough that you were damaging your hearing? Also what did the exhaust smell like? Mine smells just like a Ford 7.3 Diesel. That sickly rich burned diesel smell. Not the more normal smell from a Cummins or Kubota engine
/ New L2501 seems really loud! Suggestions? #48
Unlike the diesel truck industry, it seems the lag in Ag regs has learned from the motor vehicle's failures. The diesel trucks have finally started to be "better" again, but it took some failure because they tried to bolt fixes onto existing drivetrains rather than starting from a fresh idea.
It appears Kubota started fresh and it seems to have paid off. To date, I have not heard of any DPF/Emissions related issues on the L-series and larger tractors.
At this point i believe its a "fear of change" issue that drives 2501 sales.
Well it's loaded up and ready to head back to dealership. Thank you for everyone's help and advice on my new tractor. I hate to return it but I can't deal with the noise and diesel smell. Hopefully the L3301 will be much better.
I think this is very true.
We shall see how the L3301 does for me. I have well over 1,.200 hours operating Kubota equipment. I have high expectations and have always been pleased with Kubota engines and machinery. The L2501 is my first disappointment.
2011 Caterpillar CB34 (A60462)
2011 Caterpillar...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
12ft 5in Flat Bed (A61165)
12ft 5in Flat Bed...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
